Results 1 to 8 of 8
Thread: Coding injectors
    May 2016
    Coding injectors
    Hi,
    New Patrol (ZD30 CRD 2007) owner here. I'm looking at changing out injectors along with a few other jobs.
    Is there a way I can enter the injector codes myself ? Or do I need to take it to a workshop ?
    Previously I've worked on Toyotas, where I can do most things using Techstream. I guess I'm asking if there is software (and cable) available to do similar things on the Patrol ?
    Thanks,
    Paul
    May 2016
    Hi, just checking if anyone knows anything about this ? Can Nissan Diagnostics (NDS 2) do this ?
    As far as I know there is no coding needed, just plug and pray. Well the Di Grenade I had was that way. As for codes, there is a code stamped on the injector itself, which needs to match the new injectors.
    Feb 2023
    CRD injectors definitely have trim codes that should be entered into the ECU. Many people seem to do without and say their car runs fine, but the potential issue is cylinder-to-cylinder imbalance where some cylinders are working harder than others, and poorer idle quality. I don't know how much difference it makes in practice or how to code them, but personally I would make sure I got it done even if the difference is minor.
  5. The Following 2 Users Say Thank You to Geoff-AU For This Useful Post:
    jack (15th September 2023), MudRunnerTD (21st September 2023)
    Yea, Victoria
    https://dieselengineparts.highwayand...esults:content
    It appears that coding injectors is a valid thing.
    Sep 2023
    Quote Originally Posted by Coldcomfort View Post
    https://dieselengineparts.highwayand...esults:contentfnaf games
    The same mind.
    May 2016
    Yes it's definitely a thing. I just need to know how to do it !
    Yea, Victoria
    Has anyone found more info on this. I'll be getting my mechanic to instal new glow plugs, rocker cover and a few other bits. I'm also very tempted to have new injectors installed while its in bits. I have a OBD2 tool but I'm pretty sure that it wont do the "trimming" that is needed.
