Quote Originally Posted by DickieO View Post
Tested the old actuator and couldn't hold any vacuum with the pump. Tested the new one and did perfectly.
Followed the steps, lever is now hitting the stop screw when running!! And we now have good boost!!
Took a little bit to set the dawes to 15psi after mucking around with it a lot before starting this thread, took it for a very easy drive and honestly if felt really nice. Drove around for about 20 minutes no spikes, no high EGT, didn't feel laggy, responsive but not jerky.
Very happy at the moment, anything else i should be checking now things seem to be working properly/better?
Great result_pleased for you.
Drive it for a while see how she goes, may be able to increase boost to 16 psi.
List all eng mods you have/know of and we can go from there.
i went and bought the same actuator, installed it yesterday ($50 ebay), rod starts to lift at 5"Hg as it should and then applied 20"Hg (held vacuum) _ yes good product working well.
