Results 1 to 4 of 4
Thread: Gu patrol re4r03a 4.5
    Dec 2022
    Question Gu patrol re4r03a 4.5
    HI Maxde new to the forum first time user ,i have just recently purchased a GU Nissan 4.5 auto, we own a very steep mountain property that requires 2nd gear low range to climb in a manual cruiser ute ,so i thought ill give the GU try ,with diff locks it is fantastic no spin ,haven't tried it in the wet yet as the cruiser requires a winch to get up.
    problem is it wont engage D or Rev until it is warmed up then it is faultless, i have been reading posts tell me to change oil and filters and change ,line pressure solenoids, so i did also, used Gulf Westren syntrans
    ,clean the valve body but did not remove the valves just carby cleaner. made it a little better but still requires warm up ,there is no slip at all apologies if i have not put these questions in the correct place this site seems to be a wealth of knowledge
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Cleaning the valve body means to disassemble it so the various valves and passages can have any debris removed. It doesn't take much to cause a valve to stick if the trans hasn't had regular maintenance.
    Any mechanically capable person can do it if they follow the workshop manual.
    John
  3. The Following User Says Thank You to jff45 For This Useful Post:
    mihit (4th February 2023)
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    Dec 2022
    Ok ,Thankyou i will pull it out again and clean it properly, this Gu leaves my cruiser for dead on hill climbs .apologies to all for asking questions at the time of my introduction
