Page 63 of 64 FirstFirst ... 61626364 LastLast
Results 621 to 630 of 635
Thread: Rosscos GQ Rejuvenation
  1. #621
    Yeah old mate who I got the bar off made a 50mm receiver for trailers so will be perfect for mounting removable dildo when in the bush only. . See how we go with rope is actually 10mm tho but should do the trick hopefully. . Think last time out rope on got 40 m and chopped about 10 off to make extension but that was with standard diameter drum so deltatec get a bit more on. . Dildo 75mm think better choice than 50. .
  2. #622
    Bloody Tassie probably explains TD not loving the heat & hills. .
    We did a great job on the radiator in the bush but still $1000 dollar mud to be found. . Think TDs need everything bang on to be happy on the scorchers. .
  3. The Following User Says Thank You to Rossco For This Useful Post:
    mudnut (29th January 2022)
  4. #623
    Who would have thought that might not run to full performance - boys and their mud journeys!!
    Rossco (6th February 2022)
  6. #624
    Winch all back together not without a few dramas tho lol. . Could not get the motor out from top hat ended up drilling hole in feespool delete as that was equally impossible to get out (remember putting it in was so tight thinking this will never come out damitt). . . Anyways bit of belting on end of motor shaft out she came. . Spine that runs on bearing in freespool delete (winch gear) was flattened so explained why she wouldn't come out but unsure why the damage happened.
    Anyways fixed spline good enough, taped hole and put bolt in and and happy days. Upgraded brake shaft in and looks good, everything so much more secure than the standard warn set up. .Put winch back in car worked all good till bloody noisy and realised put ratchet plate in backwards damitt. . . Fixed that then happy days
    New rope & hook. .
    Removable dildo works a treat thought spotties might be an issue but think all good. .
    New improved delta tec clip thingy should hopefully be a bit more durable than before. . .
  7. The Following 11 Users Say Thank You to Rossco For This Useful Post:
    AB (6th February 2022), Cremulator (6th February 2022), Hodge (6th February 2022), jay see (5th February 2022), MB (5th February 2022), mudnut (5th February 2022), mudski (7th February 2022), PeeBee (5th February 2022), rusty_nail (5th February 2022), Stropp (5th February 2022), Winnie (5th February 2022)
  8. #625
    GQ back in the hills after a bit of a birthday party at the auto elec and workshop. . List of things fixed as follows. . . Had parasitic draw tracked down to faulty alternator which I need to chase up and replace as is brand new but at least know what it is. . Installed lift pump (Carter). Was thinking optima batteries both just over a year old were knackered but with new big earth strap is cranking of its head now so very happy. Pyro fixed ( needle was off chops all over the place). Fixed battery monitor not showing imput from redarc BCDC (neg wasn't going through shunt simple fix but needed fresh set of more professional eyes). Think that's about it in the auto elec department she's petty sorted now (apart from swap alternator) so ready to put in Redwinch supercharger soon. . . Picked up from there then dropped @YV4WD for new front wheel bearings, stub axles and uni joint in rear shaft bloody Tassie mud damitt. . Think she's about ready to enjoy now
  9. The Following 7 Users Say Thank You to Rossco For This Useful Post:
    AB (11th July 2022), BrazilianY60 (4th October 2022), Cremulator (11th July 2022), jack (11th July 2022), MB (12th July 2022), mudski (11th July 2022), PeeBee (11th July 2022)
  10. #626
    Legendary timbar's Avatar
    Feb 2011
    perth
    looking good old mate its been a long project !!
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  11. The Following User Says Thank You to timbar For This Useful Post:
    MB (14th July 2022)
  12. #627
    Quote Originally Posted by timbar View Post
    Haha cheers mate yeah don't think it ever ends
  13. The Following User Says Thank You to Rossco For This Useful Post:
    MB (14th July 2022)
  14. #628
    So after last trip away ARB single compressor which is pretty old and done a heap of work gave up on life, luckily held on long enough to run lockers and winch freespool for a marathon winch halfway up Mt Selma. Decided to upgrade to Little one to run lockers and winch freespool and double for tyres. . Long time coming as usual but all installed now. .
    Old single was mounted in corner and as locker compressor nice and compact managed to move that to back of aux battery tray and fit in red winch supercharger in corner spot. . Fits prefect was meant to be lol. . .
    Looking back at this thread was a year ago got everything discontented from aux battery tray to hook up 24v . . Can't rush things I spose but close now lol.
    Put double under front seat and fits a treat
    Used old fire extinguisher (cheers Daz) for air tank directly under it. .
    Got rid of most of the ARB loom and ran 6b&s through midi fuse from lithium in the back. Apart from that you can just switch the compressor from the purple wire going into it. .
    Gave it a little go and seems like it will be a beast. Certainly wouldn't want to run lockers off it if mounted in cab, she loud and also may double as a masage seat on those long and lonely trips
  15. The Following 6 Users Say Thank You to Rossco For This Useful Post:
    AB (3rd October 2022), BrazilianY60 (4th October 2022), Cremulator (2nd October 2022), MB (3rd October 2022), MB TD42 (19th April 2023), PeeBee (2nd October 2022)
  16. #629
    84 Post(s)
    I see you have the intake filter at floor level. I ran a hose under the carpet and door trims so I could mount the filter in the rear quarter panel trim card. It made it a hell of a lot quieter as the intake is so far from the piston. Now there is less chance of flooding the compressor.
  17. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    MB (3rd October 2022), MudRunnerTD (3rd October 2022), Rossco (2nd October 2022)
  18. #630
    I have my twin under the pax seat. Not that loud. Plus Catherine gets a kick out of the under seat vibes! Lol.
  19. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Hodge (3rd October 2022), MB (3rd October 2022), Rossco (2nd October 2022)
