Page 1034 of 1057 FirstFirst ... 10321033103410351036 ... LastLast
Results 10,331 to 10,340 of 10565
  1. #10331
    Cannot Thank You Enough Philstar, your generosity is always beyond belief
    Rear calipers installed this afternoon with flash new braided lines kindly gifted too!!
    Fronts awaiting a Patrolapart visit tomorrow for a rebuild rubber kit as online Sunday they appear ‘Out of Stock’ for changeover of your previous generosity twin pot GQ EFI calipers gifts and slotted rotors
    Watched some Youtubey videos today as I’ve never personally reconditioned calipers before, sexy time gloves are ready to hopefully keep grubby contaminated fingers off the seals going in deep
    One thing is for sure they should come apart a lot easier than when I re-co'd them!! Its not a big hassle for a man of your capability, only time.
    MB (26th June 2022)
  3. #10332
    Bought two x 100a/hr Itech lithium batteries for the truck to replace the 3 x 130a/hr AGM's. saved 100kg of weight. Bit of a waste in some regards as the AGM's are only 12 months old and fully functional, but the price of diesel at the moment, should have the cost recovers in a short period. I went for the 100a/hr units after contacting Itech. I want to have the capacity to use my 24v mig welder and the 100a/hr units can withstand 175amps of drawdown, which is ample for the welder. I liked that they could be configured as 4 x parallel and 4 x serial, so this works well for my coffee machine and the welder.
  4. The Following 7 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (27th June 2022), jff45 (27th June 2022), MB (26th June 2022), MudRunnerTD (2nd July 2022), Rossco (26th June 2022), Stropp (26th June 2022), Winnie (26th June 2022)
  5. #10333
    A little tip learnt the hard way again, don’t follow the final rebuild steps listed and pictured in the Haynes GQ manual:
    Found it to be impossible I believe to safely push the piston through the dust boot as their final step describes without it getting caught against the bore seal and tearing
    This trick below worked a treat and should be updated I hope by Mr Haynes:
    1) Slide the dust boot onto the piston first and lock its outer seal into position on the outer piston groove:
    2) Using the groove to hold the dust boot from sliding, stretch out the boot as long as possible and secure with fingers and thumb:
    3) Carefully slide the stretched dust boot forward out of its outer groove and off the end of the piston whilst securing it stretched as much as possible ready for installation:
    4) Commence installing the dust boot firstly and once it’s outer bore dust seal is seated carefully push the piston on through its bore fluid seal:
    Additional helpful tools, this plastic Toledo trim kit remover was great for cleaning hard to reach seal grooves and also invaluable assisting in the final dust boot and piston installation above:
  6. The Following 7 Users Say Thank You to MB For This Useful Post:
    AB (28th June 2022), Bidja (28th June 2022), Cremulator (28th June 2022), mudski (28th June 2022), PeeBee (28th June 2022), Rossco (28th June 2022), Touses (28th June 2022)
  7. #10334
    I remember rebuilding the calipers on mine when i did the TB48 brake swap and I had a hell of a time getting those boots in too.
    MB (28th June 2022)
  9. #10335
    What a nightmare this has developed into.
  10. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (28th June 2022)
  11. #10336
    MB IDIOT Debacle fixed earlier today and appears braking better than ever known before with your old GQ EFI twin pot front calipers Philstar Mate
    Thanks Rossco Legend too for assisting with pedal pumping the last of the hopeful bubbles out of its dead dry system
    95% packed and ready, just need to shut its side gates:
    Put some IDIOT Proof measures in place so this never happens AGAIN
  12. The Following 9 Users Say Thank You to MB For This Useful Post:
    Bidja (28th June 2022), Cremulator (28th June 2022), jff45 (29th June 2022), mudski (28th June 2022), PeeBee (28th June 2022), Plasnart (28th June 2022), Rossco (28th June 2022), Touses (29th June 2022), Winnie (28th June 2022)
  13. #10337
    Hopefully lesson learnt for all what a PITA but at least she's all new now in the brake department, yep the twin pots and braided lines made a big difference in the the old GQ. . . Good to see old goldie back up & running here's to some good recon / research . . .
  14. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (29th June 2022), PeeBee (28th June 2022)
  15. #10338
    Have a great trip @MB
    Bloody well done on the brake reco.
    Gong him Red!!
  16. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    MB (29th June 2022), PeeBee (28th June 2022), Rossco (29th June 2022)
  17. #10339
    Nice one Mark. Where you off too?
  18. The Following User Says Thank You to mudski For This Useful Post:
    MB (1st July 2022)
  19. #10340
    Big desert. .
  20. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (1st July 2022), mudski (30th June 2022)
