Page 1367 of 1454 FirstFirst ... 3678671267131713571365136613671368136913771417 ... LastLast
Results 13,661 to 13,670 of 14534
  1. #13661
    175 Post(s)
    It is disappointing that a small number are not heeding the instructions, but you get that in a Democracy. If you want compliance, bring in marshal law, then see how that compares to the inconveniences we are living through. I feel for those who have had their life's efforts go down the drain. this is a long term proposition and going to be here for a while yet. I am lucky, in fact in some regards happy to be locked down instead of travelling back and forth between Melb and Townsville on a plane every 2 weeks, locked up in a recirculated air environment, HEPA filters or not. My job is secure for the next 3-4 yrs, I can essentially work from home base, and that will do me out i reckon. I dont get wound up about the woes of the world because i simply know what I can and cant control. This is not a flippant post by any means. I think a different perspective needs to be adopted that is adapting to a longer term set of restriction, otherwise you are going to spiral down the 'S' bend and its only dark and messy down there. I hope this helps in some way. Try and find a positive spin, even if small.
    I found a positive spin on it PeeBee.
  2. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    Avo (7th August 2021), Mickhead (7th August 2021), PeeBee (7th August 2021), Rossco (7th August 2021)
    195 Post(s)
    Thats the way Hodge'y, its sometimes the little things that work, enjoy.
    Hodge (7th August 2021)
  6. #13663
    193 Post(s)
    Haha I feel alcohol consumption may go up in Sunny Vic this weekend lol. .
    See if you can keep the smoke inside the pvc sheathing, makes the vehicle lighter I hear! Emptying mine out right now to start putting in islation switches for all the 'noisy' electronics that are playing havoc with my HF radio. What are you adding Rossco?
    Finally getting the lithium all hooked up and rewiring everything in the back with central fuse box etc. . Going to run some wiring up to the roof with led strip lighting and light bar just cos really. . Will redo some wiring up front with fuse box pretty much just for lights then 24v for winch with two optimas under bonnet. .
  7. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    Cremulator (7th August 2021), Hodge (7th August 2021), PeeBee (7th August 2021), rusty_nail (7th August 2021)
  8. #13664
    The tight arsed local that will burn his rubbish, including plastic. Pharkin' stinks.
  9. The Following User Says Thank You to mudnut For This Useful Post:
    rusty_nail (9th August 2021)
  10. #13665
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Bugger!! The drama with glass lenses and no protective covers. This is the third set of lenses too.
  11. The Following 2 Users Say Thank You to FNQGU For This Useful Post:
    MB (11th August 2021), mudnut (11th August 2021)
  12. #13666
    465 Post(s)
    Fucking banks and useless brokers.
    Pete49 (12th August 2021)
  14. #13667
    Madness !!! Let me know where you blokes are , so I can avoid being beheaded by a panel flying off.
    Here U Go mate, this is how a solar panel is properly installed. Fitted mine off tonight, will wire it in tomorrow... Probably. Bolted and wrapped gal tophats to frame and panel fixed down with 16mm wafer screws. Ain't going to where.
  15. The Following 6 Users Say Thank You to rusty_nail For This Useful Post:
    Cremulator (11th August 2021), Hodge (12th August 2021), mudnut (12th August 2021), PeeBee (11th August 2021), Pete49 (12th August 2021), Rossco (11th August 2021)
  16. #13668
    Bloody stuck here while the young bloke is moving into a new rental. He has no hot water and the laundry tap is pissing water everywhere when the washing machine is used. The real estate agents are being arseholes about it.
  17. #13669
    SUCH IS LIFE Maxhead's Avatar
    ACT
    What has made you Angry Today???????
    Get him to fix it and then send them the bill! Happy days
    Edit- I know it’s not that easy
    But Sou da good
    ________________________
    ______ 2017 D-Max _______
  18. The Following User Says Thank You to Maxhead For This Useful Post:
  19. #13670
    109 Post(s)
    Most property managers are scum to renters. It's the only thing they're good at.
    Years later with a cheap investment property, most property managers are scum to the landlord. It's the only thing they're good at.
    In short, most property managers are scum.
    Disagree? Call me out.
  20. The Following User Says Thank You to Plasnart For This Useful Post:
