Results 1 to 10 of 20
Thread: 130 amp Alternator for 4.2tdi
Threaded View
    177 Post(s)
    The only issue I have had with the fleetguard is the back cover surface is 'sticky' when i first start up, and it sounded like I had a 'clicking' bearing - took a while to diagnose as the belt 'popping off' the idler roller. A puff with some graphite powder fixed it instantly. I mention this only as an observation and remedy if someone else strikes it.
    Phil mate, please elaborate this a tad more... You have my attention! So you're saying the outer "green" skin of the belt sticks and clicks when cold or something?
    As mentioned earlier in the thread. Slapped on a new Hitachi 100A Alternator unit not long ago. While at it I slapped on a set of the Green belts from @mudski ...
    "Sometimes" in the morning at start-up there is a minor "ticking" noise with no consistent pattern, which fades minutes after idling from start ANd/or I give it few revs...
    As the belts AND the Alt went on at the same time, I'm unsure where to begin looking, but now that you've mentioned this i'm intrigued!
  2. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    MB (15th May 2021), PeeBee (15th May 2021)
