Results 1 to 10 of 972
Threaded View
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Yes have thought about that. But will wait to see how this new fan setup goes. Took it for a spin today. Looks promising. And I thought the G35 on a fully locked viscous hub was noisy. Gawd! I sound like a whistling hovercraft now.
    Good that you have observed some improvement Mark.
    In line with what @PeeBee stated, checked my CRD fan blades_ would be lucky to covered 50% by the cowl skirt and radial tip clearance is nom 25mm (different eng mount and other flex characteristics but just reference info).
    Guess U can only give a deeper cowl a go might even quiet it down a bit.
    Mentioned it as in early 80's, I put a 4 cyl B series diesel in my FJ45 swb (two less cylinders than the original 2F petrol)_cowl extension made up using galvanized sheet/metal pop riveted in place, did not have a nutsert tool then.
    So now, with the noise from the fan and the resonance from the CC cooler she must be buzzing with noise now mate.
  2. The Following User Says Thank You to Bidja For This Useful Post:
    PeeBee (17th October 2020)
