Page 45 of 106 FirstFirst ... 4344454647 ... LastLast
Results 441 to 450 of 1053
  1. #441
    Expert Mickhead's Avatar
    Oct 2019
    This looks good. It's a MIG Gas/Gasless and MMA/Stick electrode as well as DC TIG welder.
    Bunnings have it for $500I see yours is a130 amp. Do you trip your power when using it. Talking to a few welders at work they all said go at least 170 amp.
    The bossweld MST185 at bunnings costs 500. It is a very good welder. I see industrial suppliers selling these for more dollars..You will need to pay an extra $160 for a tig torch. And $299 for ownership of a d size argon bottle with $99 Swaps when empty. And 20 bucks for a better arc handle. I bought the tig torch. This unit is lift tig which is easy to use but not as good as hf which you will find on higher end tigs. What impressed me about the tig on this unit is that the low end of the amp scale is accurate. You can weld really thin shyt with this. Then I got the TS200 ac dc at a good price with no torch or any accessories... The tig control plug is different. I rang the supplier Dynaweld fully expecting them to tell me to fark off and buy another tig torch, but instead they talked me thru the process and sent me wiring diagrams !
    Awesome service.
    Take eveyones advice and dont use gasless wire. It is horrible messy crep. My roll went in the bin after using it for 30 seconds.
  2. The Following User Says Thank You to Mickhead For This Useful Post:
    MB (13th August 2020)
  3. #442
    Honestly I don't think I ever need a tig. I've gone this long without a welder at all. I can always get stuff welded at work if need be. I can pretty much get steel from work cut and bent to whatever size I need, just want something to play around with at home.
    Point taken no gasless..
  4. The Following User Says Thank You to jay see For This Useful Post:
    Mickhead (14th August 2020)
  5. #443
    Quote Originally Posted by Mickhead View Post
    The MST185 is excellent too Attachment 81669Attachment 81669
    Wow! You cat looks exactly like my boy.
  7. #444
    483 Post(s)
    A beautiful 24/7 indoor boy too Mr Mark, 8:00pm curfews are keeping us humans in check and dropping casualties finally!
    mudski (13th August 2020)
  9. #445
    Awesome service.
    What are your thoughts on the Rossi brand - this one in particular? garage use only. I have the 130amp mig at the moment , again a Rossi, but even on gas and full power it does not lay a good bead - struggles to get the metal down and its a generally horrible looking result - i am resigned to park it under the bench.
    https://www.ebay.com.au/itm/ROSSI-22...53.m1438.l2649
  10. The Following User Says Thank You to PeeBee For This Useful Post:
    jay see (14th August 2020)
  11. #446
    Yeah 24/7 indoor for sure. That goes for him and his brother.
  12. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (13th August 2020), Mickhead (14th August 2020)
  13. #447
    Oct 2019
    Rossi is a Brazilian brand.they are very light, but well built. The crescent stainless buttplate can be nasty with heavy loads. Awesome, 5 stars 9418309E-F5A4-4704-87CF-281668F8B2E8.jpeg
  14. The Following User Says Thank You to Mickhead For This Useful Post:
    MB (16th August 2020)
  15. #448
    Thanks but no idea what this means "The crescent stainless buttplate can be nasty with heavy loads. Awesome, 5 stars ??????
  16. The Following User Says Thank You to PeeBee For This Useful Post:
  17. #449
    Oct 2019
    Oops wrong Rossi
    Seriously tho.. had a Rossi ebay inverter mig for a short time, sold it quickly due to horrid feed and lack of support. Rossi is an ebay brand that sounds nice.. like detroit and chicago trying to be milwaukee..
  18. The Following User Says Thank You to Mickhead For This Useful Post:
  19. #450
    Oct 2019
    Cats are awesome under rated creatures Mine rules the house and the dogs and the man cave
  20. The Following User Says Thank You to Mickhead For This Useful Post:
    mudski (14th August 2020)
