Results 1 to 7 of 7
Thread: 2001 GU blown zd30 di & Getting TD42 converted and cleaned up
Threaded View
  1. #5
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by Jdugg27 View Post
    Trying my best to do it right the first time, unfortunately I do lack a lot of mechanical knowledge so I do have to have a lot of faith in the mechanic.
    Run it past the forum here before you lock in your hard earned mate. UFI will build you a brand new pump for what ever horsepower you're after. It'll need a bit more fuel if you wanna run 20psi. Give them a call and tell them what you want. Helped steer me in the right direction. There are plenty of other reputable pump/turbo specialists out there too, I just liked the service from UFI. Just do a bit of shopping around for your turbo and pump. Don't let the mechanic lock you into a standard pump and turbo for a premium price.
    Edit: I also meant to say that UFI were quite reasonably priced and will give you good advice between 11 & 12mm pumps depending on your budget and hp build.
  2. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    Jdugg27 (3rd June 2020)
