Results 1 to 7 of 7
Thread: Diff lock indicator switch
    Advanced Mentok's Avatar
    Apr 2011
    Tindal, NT
    G'day everyone,
    I have had a few Diff lock issues with my 2015 Patrol and wanted to know if anyone has a part number for the diff lock indicator switch that is located on the diff lock actuator on the rear diff? The switch is corroded and has a resistance of 2.7k ohm. I have contacted a Nissan dealer and they quoted me $1250.00 for the whole actuator as they can't find an individual part number/price for just the switch. I have had a look at a few other switches on the Patrol and it looks like the neutral switch maybe a similar switch. Can anyone confirm that?
    Muzz
    2015 GU ST Patrol, ZD30, Manual, 3" AmadaXtreme Explorer II Shocks with Dobinson Flexi coils, Warn XD9000 Winch, 33" BFG Mud Terrains, IPF Spotties, ORS Drawers, 3" DEA exhaust, catch can, Tillex valve.
    Sep 2018
    queensland
    see image the electrical part is apart of the actuator
    33250VB30A
    stock in melbourne list price is $1486.66+gst
    so what you were quoted is good as trade is $1263.66+gst
    the switch looks alot like the reverse switch on the rh side of the gearbox. it would have a different connector no doubt but maybe try pull the reverse on out and compare them. if it threads in just cut the wire and put the plug on it and buy a reverse switch. 32005-21U1B
    Apr 2011
    Tindal, NT
    I ordered in the reverse switch and it fit in the diff lock actuator perfectly however did not fix the issue as the switch is a normally open (no resistance/circuit when extended) switch and the diff lock indication switch is a normally closed switch. By design the diff lock actuator plate sits outboard and pushes the switch in which opens the diff lock indication switch (no circuit). So when the diff lock is engaged the diff lock actuator plate moves inboard and the switch extends and closes the switch (creates circuit). The 2 other switches I was looking for alternate switches were the transfer case neutral switch and neutral position switch. My question is does anyone know if either of those switches are a normally closed switch?
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    My sway bar disconnect seems to be open until lever is pulled. Can remove cable and place volt meter on switch terminals set to read resistance and check the switch...if it reads when depressed it must be that its a open circuit when not in use.
    Hope that helps...
    PS...I am a trial and error repairer...follow at own risk
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  5. #5
    Apr 2011
    Tindal, NT
    The switch sounds the same as the reverse switch. The switch is open until it is pressed (placed in reverse) then it makes a circuit. I am after the reverse of that.
  6. #6
    Quote Originally Posted by Fireblade View Post
    33250VB30A
    Can be had brand new and genuine for half that price mate.
  7. #7
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by Mentok View Post
    Bit janky but.. You could use it in conjunction with a normally closed relay and have your switch activate that. Not pretty but may save you $1400
