Results 31 to 37 of 37
Thread: top shock mount stuffed. HELP.
  1. #31
    22 Post(s)
    Easiest and cheapest way would be to drill and tap and use a bolt with a large washer to hold it on.
    Or, get a complete shock mount and weld that in.
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Count Grantleyish (23rd February 2020)
  3. #32
    Nov 2019
    Melbz
    Sounds easy with a ute not in a wagon :/
    Body off to access these...
  4. #33
    Nov 2019
    Melbz
    Thanks again for the suggestion, will have a think whether it's feasible to go ahead or not.
  5. #34
    22 Post(s)
    No, just get from underneath. No need to remove the body
    96 GQ coil/Cab
    08 G6eT
  6. #35
    Nov 2019
    Melbz
    From what I can see, there aren't much room to use the drill of any sort even if I take springs out.
  7. #36
    22 Post(s)
    Well, that just leaves cutting the old mount out and welding anew one in
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  9. #37
    Nov 2019
    Melbz
    Yeah, prob cost fair bit in labour since I don't have space and tools for that job.
    Thanks again.
