Page 3 of 15 FirstFirst 12345 ... LastLast
Results 21 to 30 of 142
Thread: Rear Winches - Lowering Down versus Hauling Dead Vehicles Up
    483 Post(s)
    An F350 stump remover tends to test em out, snatch blocked and all :-)
  2. #22
    And big fat ass GUIVs stuck to the xhassis in Soupy muddy snow 90 degrees off the track.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (28th August 2018)
  4. #23
    483 Post(s)
    And minutes after your recovery a GU1 ute slid off too, thankyou Sir & Sir winch tough torque rebuild advice
    MudRunnerTD (28th August 2018)
  6. #24
    483 Post(s)
    Sadly another busy year has gone by, shed queen is still awaiting TLC including previously planned add ons as per the 17,000lb Mule for its rear purchased above.
    Family fun adventures in the old faithful GU wagon are taking first place of late and wondering whether or not the Mule could assist hauling our barge?
    Our wagons current old faithful Warn 9,000lb low mount I seriously doubt will handle an upcoming planned adventure and looking towards getting the twin motor Mule up under there.
    Measurements today find it could easily fit width wise albeit needs the mounting holes and fairlead shifted left some 20-25mm.
    Is there any issues, legal or otherwise with butchering up a bullbar to get this beast on board a GU?
  7. #25
    Only airbag compliance. Don't alter that and your all good
    MB (5th November 2019)
  9. #26
    Re-drilling 4 holes won't make any difference to the structure as it sits. The only hesitant or watch point is the potential to now be able to extrude that hulk with a bigger winch, ie 9000 V 17000lb and there might be a requirement to double line pull, 34000lb worst case at stall - could happen if you were in a sticking suction type situation. Ring the bar manufacturer and find out what the design capacity is. Happy to run some numbers for you on the mounts - need dia, no off, thread form, will see how you would travel worst case.
  10. The Following User Says Thank You to PeeBee For This Useful Post:
  11. #27
    483 Post(s)
    Cheers Philstar!
    Bars off the ute originally from WA, can’t honestly remember the popular day maker there but knowledgeable blokes once said they were renowned for camel proofing trucks there with W.T 8.8 bolts galore as reinstalled underneath.
    A weakest link theory may have to be downgrading rope to 10 or 11mm instead of 12mm as purchased for the utes arse end beast plans originally?
  12. #28
    @MB how much rope did you buy mate? What size did you get?
  13. #29
    483 Post(s)
    12mm 45m
    MudRunnerTD (5th November 2019)
  15. #30
    12mm 45m
    Nice, is that for your GU Ute front yeah?
    You could fit the himount to the front of the wagon for.your trip mate.
