Results 1 to 10 of 56
Thread: Anyone using snatch rings?
Threaded View
  1. #32
    I use a chafe sleeve on my softies anytime I think they may be subject to friction heat or severe abrasion.
    You can use an old length of sleeve off a knackered Winch Rope or buy some.
    All you do is cut it to length and slide it over the softie.
    It's only like 10 to 15 bucks a metre and that metre will give you 3 or 4 sleeves at least.
    If you identify a need you slip a sleeve over the softie, attach the softie, do the deed, remove the softie and check for damage... just like using a...uuummmmm... nah, won't go there.
    https://www.ebay.com/itm/Premium-Qua...lvWlJmGhKNdr7w
  2. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    10G (7th June 2019), MudRunnerTD (7th June 2019), PeeBee (7th June 2019)
