Results 1 to 5 of 5
Thread: Expected cruising boost
    Gold Coast
    Question Expected cruising boost
    DDi 3.0 (not common rail)
    Does anyone know the expected unmodified boost pressure when cruising around 90 - 100 km/hr.
    Alternatively, what pressures are you experiencing??
    Seems I get between 9 and 12 psi without much throttle.
    Checking small stuff as I have a brand new rebuild to run in.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I have the same motor with dawes and I get about that reading. long haul at 100k sits on 10psi when crusing, so 9 to 12 sound about right. I limit it at 15psi but you really have to put the boot in to get it over 12 or so. Hope that helps. Cheers Tony
  3. The Following User Says Thank You to 4bye4 For This Useful Post:
    Dr Gary (15th May 2019)
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    10 @ 100 on the highway.
    16 max.
  5. The Following User Says Thank You to Mc4by For This Useful Post:
    X2 10psi @ 100kph is the norm what are you driving manual or auto
    as that will be different revs at 100 kph
  8. #5
    Gold Coast
    So with the knowledgeable responses I am satisfied that I have it about right. Thanks to all.
