29th July 2011, 10:36 PM
model facts 1986
1986 NISSAN PATROL (4x4)
2Door HARDTOP 2 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
» Release Date: Jan-1986
» Max. Torque: 201Nm
» Max. Power: 88kW
» Power to Weight Ratio: 19.6:1 kW/kg
» Fuel Type: UNLEADED PETROL
» Dimensions: L(4070mm), H(1880mm), W(1690mm)
» Towing Capacity: Brake(2400kg), Unbrake(750kg)
» Turning Circle: 11.8m
2Door HARDTOP 4 SEATS, 4WD, DIESEL, 5 SP MANUAL 4x4
» Release Date: Jan-1984
» Max. Torque: 215Nm
» Max. Power: 70kW
» Power to Weight Ratio: 27.07:1 kW/kg
» Fuel Type: DIESEL
P/UP 3 SEATS, 4WD, DIESEL, 5 SP MANUAL 4x4
» Max. Power: 70kW
» Power to Weight Ratio: 24.21:1 kW/kg
» Fuel Type: DIESEL
» Dimensions: L(4785mm), H(1895mm), W(1690mm)
» Turning Circle: 14.2m
1986 NISSAN PATROL DELUXE
4Door WAGON 7 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
» Max. Power: 88kW
» Power to Weight Ratio: 20.91:1 kW/kg
» Dimensions: L(4690mm), H(1845mm), W(1690mm)
4Door WAGON 7 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
» Max. Torque: 255Nm
» Max. Power: 81kW
» Power to Weight Ratio: 25.19:1 kW/kg
» Fuel Type: DIESEL
1986 NISSAN PATROL GL
2Door HARDTOP 4 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
» Release Date: Jan-1985
» Max. Power: 88kW
» Fuel Type: LEADED PETROL
» Max. Power: 70kW
» Fuel Type: DIESEL
18th December 2018, 12:09 AM
top gen. thanks .hope you are well.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
