Page 104 of 116 FirstFirst ... 102103104105106 ... LastLast
Results 1,031 to 1,040 of 1157
Thread: Winnies 747 TD42 GQ
  1. #1031
    Is that first photo untouched and after that you wiped them clean?
  2. #1032
    I haven't cleaned anything. The first pic is the bores and the 2nd pic is the head.
  3. #1033
    Sorry I see what you mean now. In the last pic of the piston in the bore I had pushed it down and the flash on the camera made it look cleaner.
  4. #1034
    22 Post(s)
    That white powdery buildup is coolant
    96 GQ coil/Cab
    08 G6eT
  5. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (23rd October 2018), Winnie (23rd October 2018)
  6. #1035
    Hopefully Matty can shimmer in but your burn marks to me look good but no idea on the soot on number 2. It was number 2 that went yeah?
  7. #1036
    Yeah it was. Same as yours yeah?
    Yeah okay I guess that confirms what happened then as Mat guessed to begin with.
  8. #1037
    Yep same mate. Well there you go hey mate, contamination, how the hell did it get in???
  9. #1038
    22 Post(s)
    Yeah it was. Same as yours yeah? Yeah okay I guess that confirms what happened then as Mat guessed to begin with.
    And the rust on the liner above the rings.
    96 GQ coil/Cab
    08 G6eT
  10. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  11. #1039
    It must have been exhaust gases pushing the coolant out of the overflow, but there was definitely no bubbles in the radiator.
  12. #1040
    22 Post(s)
    You can see where the combustion was tracking.
    96 GQ coil/Cab
    08 G6eT
