Page 1162 of 1465 FirstFirst ... 11601161116211631164 ... LastLast
Results 11,611 to 11,620 of 14644
  1. #11611
    Why did our Yanky ‘Odyssey’ friends move out? Plate vertical batteries with sealed epoxy say tops and bottoms for vibrations, too expensive?
  2. #11612
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    They are still around
  3. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    MB (26th June 2018)
  4. #11613
    They were renowned in circles as the best of the best in their day, what’s your thoughts YB mate, I’ve never owned/used one?
  5. #11614
    Aug 2016
    Jimboomba
    4 Post(s)
    Great cranking but for a short period. Generally last a long time but no good for deep cycle work. Great in race cars
  6. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    MB (26th June 2018)
  7. #11615
    177 Post(s)
    I'm more cheesed off at my self, as I HAD the aux battery setup in the rear, and then once I got some draws due to space limitations and no feasable battery spot, I slotted it back in the front.
    Either way, heat or not, the battery is rooted now. Even though it was a fairly expensive one for a 85AH. Live and learn. Just spent some time at the rear of the patrol, conjuring up ideas and pretty sure the aux setup is going to the rear again. Most of my wiring is there already so, not a huge job.
    MB (27th June 2018)
  9. #11616
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Ive got 2 odyssey's under the bonnet in my patrol, cant fault them at all. And the best bit...they were free!!
  10. The Following 2 Users Say Thank You to firm351 For This Useful Post:
    MB (27th June 2018), Yeti's Beast (27th June 2018)
  11. #11617
    It was suggested to me Eric from someone that if I wanted to have the battery in the rear with draws there also, that I should look at shortening one of the drawers enough so that the battery can sit behind the draws. I was also thinking of some how tucking it in the side above the wheel arch where that pocket is. I let would be half hanging out of course so some fabrication work would have to be done to secure and hide the battery.
    Sent from my crapPhone using Tapatalk
    MB (29th June 2018)
  13. #11618
    177 Post(s)
    Markie. You're a mind reader !!!!!
    I spent a bit of time this arvo looking at just that and measuring up and getting come bracketry ideas. And I think I've come up with something.
    Will lose around 18cm of the draw, which is bugger all. The end of the draw is easy to grind the welds , cut the to size and weld or rivet the end back on. Drill some new holes for the rubber stops and voila!!! Battery hidden away and still easily accesible when you slide the draw slide open.
    I got the idea of someone else who has done it on the other patrol forum. Also , there are a few people with shorty GQ's who have shortened them draws to suit the back of the shorty!
    Watch this space!
  14. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    MB (29th June 2018), mudski (28th June 2018)
  15. #11619
    Watch this space!
    I'll be watching....
  16. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Hodge (28th June 2018), MB (29th June 2018)
  17. #11620
    What has made you Angry Today???????
    @Hodge mate, @jaysee mate did a great mod like that and kindly posted on here a while ago. Squeezed a whopping 140AH behind his shortened drawers he modified himself too.
    In his build thread: ‘Jay see 1997 GU build up’ (apologies, don’t know how to hyperlinky to it on Tapatalk)
  18. The Following 3 Users Say Thank You to MB For This Useful Post:
    Bidja (29th June 2018), Hodge (29th June 2018), mudski (29th June 2018)
