Thank you Gents appreciated all!
You’re on the money again there thanks ET, just rang Patrol Apart and was quoted under $200 for a good OEM second hand one. Suggestion was also to just custom mount it higher with some steel work as I’m happy with the OEM volume for my needs. Was mentioned that one of their personal tourer utes cost over $1,100 smackers for a 160L custom tank spanning hard underneath the tray to same OEM underneath clearance with 3mm plate base. Even if I only went 80L custom built raised tank sounds like the same OEM raised outcome for approximately under 1/5 of the price.
Next struggle I’m imagining rearing its head is getting diesel into the bugger as the filler lines going to be very close to level :-(
