Results 1 to 10 of 11
Thread: Intercooler Recommendation
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Hello,
    Looks like I have a pinhole in my Intercooler, what replacement do the gurus recommend (and why)?
    I've seen some cheap eBay specials and some ridiculously priced ones up to $1600.
    Jack
    2024 Isuzu MUX
    Do you have a budget Jack?
    Ballarat Area
    26 Post(s)
    Unfortunately yes I do, and I'd like it to fit the standard hole in the bonnet.
    Jack
    2024 Isuzu MUX
    476 Post(s)
    For a stock motor Jack, the cheap welded units will be fine. In my opinion, for a 3ltr, the cost per performance gain buying a top end cooler would not be worth it at all. A taller scoop will be far more effective than the OEM scoop.
    jack (12th March 2018)
    One of the companies that does a welded recore should fine. Or one of the cheap units like mudski describes. I believe there some hpd knockoff ones available one eBay for a reasonable price.
  7. The Following User Says Thank You to nissannewby For This Useful Post:
    Ballarat Area
    26 Post(s)
    Thanks guys, appreciated. Do you have any links?
    Jack
    2024 Isuzu MUX
    177 Post(s)
    On my 3L CRD I've used a DieselSmart unit.
    It was ducks nuts compared to the leaky factory unit.
  10. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Avo (14th March 2018), jack (13th March 2018)
  11. #8
    177 Post(s)
  12. The Following User Says Thank You to Hodge For This Useful Post:
  13. #9
    Jul 2015
    I have just upded to a diesel smart replacement has thermo fan and is 40% more volume of air
    Full replacement
    Went in great no issue
    Drivers nicely
  14. The Following User Says Thank You to Fwdpatrol For This Useful Post:
  15. #10
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Jack, when I was installing NADS to my CRD (run max boost 22psi, ecu remap). I replaced the leaking OEM I/C with a unit that looks the same as Hodge pics (TIG welded).
    It is a Chinese import that ADRAD supply (pt# CACBPNIS005CM) $470+gst (Aug 17). Works fine. PM me and I can let you know where purchased (ACT) if you would like to check out. They post gear all over.
  16. The Following User Says Thank You to Bidja For This Useful Post:
