Results 1 to 9 of 9
Thread: Auto trans for GU 4.2
    Feb 2018
    Hi everybody
    Is it possible to convert my patrol GU 4.2 atmos 2000 MY manual to automatic gearbox and what is the suitable autobox if such a the conversion is possible ?
    Feb 2011
    Shed
    45 Post(s)
    I think the zd30 auto box fits mate
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yeah it should you need someone in the know because there is some extra wiring involved courtesy of the TCU but wholesale automatics might be able to help you with what you need .
    Don't forget a torque lock up kit either diy or buy one from wholesale automatics gives you an amazing drive and so much better for towing .
    Beginner Sparky92's Avatar
    Dec 2017
    Adelaide
    Ive seen a couple of zd30 autos behind the 4.2 in conversions as posted above you just need a good auto elec and somone to make it work
    2004 GU3 TD42T
  5. #5
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    https://automatictransmission.com.au...on-conversion/
    Best 2 ring Wholesale Auto's and discuss with them what you are trying 2 achieve
  6. #6
    I got a feeling the OP is not from OZ...
  7. #7
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I thought so too with the timestamp..
    John
  8. #8
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    I asked the question of them last year...
    Quote Originally Posted by Wholesale Auto
    The complete Heavy Duty “Genuine” Nissan GU 5 Speed Tip Tronic Automatic Transmission conversion with Heavy Duty Nomad Valve Body and Billet Torque Convertor Fully Fitted in Perthand pre-dyno tested is $20,850 inc gst.
    The Conversion Includes:
    All Fitting and Wiring
    Heavy Duty Nissan 5 Speed Tip Tronic Overdrive Automatic Transmission
    Nissan Bell Housing
    Heavy Duty Recalibrated Nomad Valve Body Assembly
    Nissan Drive Plate Assembly
    Super-Sized Oil Cooler
    Cooler Lines , Fitting Etc
    Filler Tube & Dip Stick
    Inhibitor Switch Assembly
    Complete Centre Console Assembly with Genuine Nissan Tip Tronic T.bar
    Wide Automatic Style Brake Peddle
    Full Synthetic Oil
    Stand Alone Transmission ECU
    Wiring Harness
    Dash Display/Programmer
    *Choose Between Full Manual Or Full Automatic via Tip Tronic T.bar
    *Lock-Up Manual Control for 100% Engine Braking At The Touch Of A Button
    *Built In Temp Gauge
    *Fully Adjustable To Your Own Requirements
    *Australian Back Up & Technical Support
    Needless to say, i'm still running manual.
    For drug money like that, i'd rather spend a bit extra and go Duramax/Allison
    Jon
  9. The Following User Says Thank You to TheFlyingBadger For This Useful Post:
    NissanGQ4.2 (10th February 2018)
  10. #9
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yep that's dear enough all right but as a diy would be peanuts compared to that just a bit of hard graft and lots of swearing
