Hey guys,
I am starting to lose my mind and am hoping somebody may have some advice that can help.
I recently bought an '03 ZD30 GU, all factory, no mods at all.
a few days after I bought it, it started throwing engine lights with code 77, I had a reconditioned fuel pump put in under warranty. when I picked the car up, it started throwing engine lights with code 77......... back to the mechanic, another reconditioned fuel pump.
got the phone call that is was all ready to go, picked it up.... halfway home, code 77. I turned back around and took it straight back to the mechanic, his solution you ask??? another fuel pump!!!!!
so far, this patrol has had 3 reconditioned fuel pumps, numerous new filters (currently has a Nissan one installed), has had a new water sensor fitted for the bottom of the filter, fuel lines have been pressure tested to check for air leak, I have pulled out and checked the fuel pickup in the tank, the fuel tanks are both spotless and the fuel is crystal clear...................... still throws code 77.
It does seem to throw codes when the main tank gets between 3/4 and 1/2 or lower, don't seem to have much drama when the tank is full.
does anybody have any experience with this? is there something I am missing? I am about ready to either flick a lit match into the bloody thing....... or worse yet, trade it in for a Toyota!!!
any help would be appreciated..
cheers,
