who needs a demister when you have those awsome vents
OH LEATHER IS NICE
PeeBee (30th September 2017), Yeti's Beast (30th September 2017)
Brakes while watching bathurst
Took the throttle body off the ZD30 today and was surprised that there wasn’t that much gunk in there. I believe it’s the first time it’s been cleaned. Carefully cleaned what I could from the intake and removed the flap off the swirl valve. Egr is already blocked. Don’t know if it’s my imagination but I think it goes better
Been chasing a coolant leak for the last couple days, and finally tracked it down to a small section of cracked hose joiner, now just gotta work out which part it is - think it's one of these two:
http://patrolapart.com.au/product/ge...gr-heater-hose
http://patrolapart.com.au/product/ge...-to-water-pump
Also took of my recovery points off that were looking a little bit sad and prepped them up for a quick spray
I did a river crossing today, exactly the same way I have crossed this river over 50 times, and had 6 out of 8 blades fracture on the fan hub and have scored the radiator, but its not leaking. Extreme shuddering and vibration at 2000rpm, but being a coolish day, didn't affect the engine temps. Looking for a new tougher fan blade system and will use a radiator shroud next time. the GU patrol , a hiluxDSC01863.JPGDSC01862.JPG and a Terrano that followed and did exactly the same crossing, without shrouds, came thru fine. the fan blades are 3000klm old. Not happy.
Shitty batch of fan blades maybe ?
Reckon the material is too hard/brittle and they are also too close to the core to allow for any deflection. I have not put a ruler in it yet to gauge the differences with the other vehicles. Could have been disastrous based on the tough climb out to the road and a recovery would have been complicated to a point where it could be towed home if it overheated.
Took it on an epic adventure through the high country for a long weekend with friends.
Perfect weather, perfect company, really good tracks, climbs, river crossings, etc!
Loved the new diffs, went up a pretty hard section in particular with full articulation on all sides, short but steep climb and no scrubbing which was a surprise!
My handbrake cable snapped on a morning start for some reason which was strange but a flawless weekend nonetheless.
starting to get used to the new diffs, I like a lot!
