Page 1024 of 1467 FirstFirst ... 10221023102410251026 ... LastLast
Results 10,231 to 10,240 of 14662
  1. #10231
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    That's not ideal @bigguwesty
  2. The Following User Says Thank You to Sprock For This Useful Post:
    BigRAWesty (29th July 2017)
  3. #10232
    Pussy,,,they owe you,,,you have saved them from their daughgter...
    Or from the sounds of it, have saved their daughter from them.
  4. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Avo (29th July 2017), BigRAWesty (29th July 2017)
  5. #10233
    Well... actually..
    (Hope she never sees that..)
    Nov 2010
    Getting a life...
    38 Post(s)
    Bloody Banks. Made sure when we took 2nd morgage, No fees if paid out early' . No problem, they said. FWD 5 years. $250 'admin' fee. Oh, and if you'd like an A4 sheet of paper with 'title' written on it, another $250. Thanks very much. It's our friggin title, hand it over.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  7. #10235
    Yep understand the frustration, paid ours off leaving a $1 balance, so the line of credit remained and no early exit fee. Just have to be ahead of the game a bit and play them at the same game. No doubt when we pull the pin here and downsize, we will get hit with the same frustration you are experiencing,.
    katwoman (30th July 2017)
  9. #10236
    Running out of water in the main house tank in the middle of winter, crazy dry winter for us!
  10. #10237
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Ours overflows every time it rains AB , still wet in the hills around here must be just north of the divide .
  11. #10238
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Well you're just not trying hard enough. Take the advice of Dr Clunk...... Twice a day, morning before going to work, so that you're not starting the working day full of angst. Then showertime at night to rub away any angst that has built up during the day. If required, then one during lunch is permissible.
    Hahahaha sound advice there @AB 😝😂
  12. #10239
    Jun 2015
    Heyfield Vic
    35 Post(s)
    We've had about 20ml in the last 2 , my uncles farm at Neerim nth ( between Warragul & Noojee ) has had NEARLY 100ml for July & had 100ml for June . Just won't rain at home ,the trip up the snow was evident if the dry conditions- rivers that are normally over the bonnet were barley bottom of the rim deep .
  13. The Following User Says Thank You to Sprock For This Useful Post:
    MB (1st August 2017)
  14. #10240
    .......... TPC's Avatar
    63 Post(s)
    Long way from you guys but we had almost no rainfall in June and over 130mm for July and August looks like it is going to be very wet.
  15. The Following User Says Thank You to TPC For This Useful Post:
    mudnut (1st August 2017)
