Results 1 to 6 of 6
Thread: The Ways the Head Gasket, Head, Engine Block can fail
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    Below are the scenarios that I can think of the ways the engine fails due to head, head gasket or engine block issues.
    • Water to oil
    • Oil to water
    • Water to combustion chamber
    • Oil to combustion chamber(Rare I think?)
    • Water to outside
    • Oil to outside
    • Compression issues from combustion gas leak cylinder to cylinder
      cylinder to outside
      cylinder to water (or oil)
      valve seat/valve recession)
    • Compression, oil blow-by, smoke issues from worn oil scraper rings
    • Smoke issues from worn valve guide seals(smoke on idling, no smoke on revving)
    Let me know if I need to correct or add more scenarios or details.
    Thanx
    Dom
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Jun 2017
    I think you have it covered
  3. The Following User Says Thank You to fat mick For This Useful Post:
    dom14 (13th July 2017)
    Expert UncleFrosty's Avatar
    Aug 2016
    Goldfields WA
    Not sure on the "rarity" of point #4 @dom14...
    Any opinions @AB??? ;-)
  5. The Following 2 Users Say Thank You to UncleFrosty For This Useful Post:
    AB (13th July 2017), dom14 (13th July 2017)
    Feb 2012
    Camden, NSW
    Oil to combustion chamber, worn scraper rings, worn cylinder bore, worn valve guides
  7. The Following User Says Thank You to Turtle_au For This Useful Post:
  8. #5
    Feb 2012
    Camden, NSW
    What about the inside out.....rod through block
  9. The Following 2 Users Say Thank You to Turtle_au For This Useful Post:
    dom14 (13th July 2017), Tip12345 (14th July 2017)
  10. #6
    38 Post(s)
    Quote Originally Posted by UncleFrosty View Post
    I'm not sure either. It's just a thought that popped into my head.
    I wasn't actually taking the excessive blow-by from piston ring wear into account.
    That needs to be added.
    Cheetah Outreach
