Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Just a thought.
    Did it hurt?
    It was fleeting, so not too much
  2. #12
    Quote Originally Posted by Bush Ranger View Post
    Had a thought in my head for a few days now, on a cheap and simple portable fire place / BBQ. I was thinking of getting a metal 20 litre drum like a Frytol oil drum or similar and cut a square opening in it about half way down, whilst using the square piece as a door with a hinge. Drill a couple of holes just below that to slide a couple of metal rods through and then rest a smallish holed wire mesh on top of them to hold the wood on and I thought the base of the drum would help contain the ash as it falls through the mesh / fire grate, then put an old plough disc on top of the drum. I have also thought of using an old 60 litre drum too. I haven`t thought much about a chimney, but it would probably get put on some where and the only other thing would be a flare up from the fire when the oil / fat dribbles down the hole of the plough disc. Any one else have ideas that they have thought of and never acted on?
    PS; Thought a chimney (metal pipe) of yay high could be welded on the hole of the plough disc.
    The Yanks call them 'barrel stoves'.
    You will see heaps of them on the doco's and lifestyle shows out of Alaska and Canada (Life below Zero, The Last Alaskans etc etc)
    They tend to use bigger drums (200 mostly) but all a matter of scale I spose as they work a treat.
    One bloke knocked up a Space Heater with a Pizza Oven style top using a 200 litre drum in a few hours on a recent episode.
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    Bush Ranger (19th June 2017)
  4. #13
    Jul 2013
    @the evil twin . Since you mentioned 200 (44 gal), I remember episodes of MASH that has a 200 litre drum in the swamp tent with a chimney to keep them warm. Nothing like creating an idea that has already been thought of and made into.
    I might go ahead with the plough disc and 20 - 40 litre drum.
  5. #14
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I found my bolt together BBQ / Fire pit
    But instead of it saying Jack Daniels it will say Jim Beam
  6. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Bush Ranger (26th June 2017)
  7. #15
    Patrol Freak Gecko17's Avatar
    Mar 2013
    a little bigger than you were thinking but definitely portable...
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  8. The Following 2 Users Say Thank You to Gecko17 For This Useful Post:
    Clunk (27th June 2017), NissanGQ4.2 (27th June 2017)
  9. #16
    Dec 2015
    WA
    5 Post(s)
    Not as light/portable, but a few people at the country speedway tracks have truck brake drums welded together for fire pits. Google has some good pics.
    Graham
  10. #17
    Jul 2013
    @GeeYou8 I had two old truck rims from a 8 ton truck and I bolted the drum brake to it as a stand, but never gotten around to weld the two rims together. I took one camping a few times for a fire pit and an old iron hot plate slide half way on to it. I left it at the last camp site I was at whilst living in WA and thought the bloke I camped with would use it more than I.
  11. #18
    But instead of it saying Jack Daniels it will say Jim "Goats Piss" Beam
    Fixed it for ya Toddie...
  12. #19
    Aug 2010
    17 Post(s)
    How dare you say that..... me and mr beam have many fond memories together....... none that I can remember though
  13. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    mudski (27th June 2017)
