Results 1 to 10 of 13
Thread: Boost/EGT necessary for 2014 CRD with 3" Exhaust
Threaded View
  1. #12
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    A Dawes valve is basically a small spring actuated valve added to the vacuum lines that control the turbo vanes (and therefore boost amount). It's useful to help flatten out spikes in boost over rev range and also (primarily) to prevent over boost. Over boost (say > 20psi or less even for some) can cause serious damage as well as put your motor in to limp mode.
    That's my newby explanation. Others can give you heaps more and better info. If you search for Dawes or Tillex here you'll get about 2 days reading on it.
    I would add the exhaust first. And make sure it has a port for the EGT gauge probe to go into.
    Quote Originally Posted by Matwil View Post
    I found this very interesting as I am looking to add a 3" exhaust to my 2016 GU Patrol, and it was recommended that I put in the Boost Gauge and a pyro gauge first. I will most probably look at an ECU remap as we will be towing a Tvan on a long trip later this year to the Kimberleys and beyond.
    Can I ask what is a Dawes
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  2. The Following User Says Thank You to Boinzo For This Useful Post:
    Matwil (2nd June 2017)
