And behind said panel.
Fuse bank off to the side
			EBay mate. They are projecta terminals
http://m.ebay.com.au/itm/151430059726
I bought them in a set for about 30 bucks but can't find the seller now
They have 3 clamp connections also. One I'm using for my starter but the other two are pretty small maybe 6 gauge would be the biggest
Lucus30's 1999 GU ST TB45E
mudski (21st March 2015), Tallion_o7 (24th November 2024)
				Thanks Lucas. Just look in your purchase history. You will find the seller there.
				Any repco, Autobarn etc will have them.
I got mine from parts stop as they deal in the truck industry to so mine are heavy duty.
				Here is mine I'll be attacking today with new ones and a new main battery.
			.gif)
				That looks neat compared to mine Hodge .
				Pour boiling water over the terminal to clean off the corrosion and the get some Corrode Cure or similar and soak that puppy in it until theres no bare section of the terminal left. Corrosion simply starts from battery vapours weeping out from the battery casing and where the terminal comes though. So even those round terminal pads will help. But if the corrosion has gone down the cable itself. Time to change them.
