Page 15 of 24 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 239
Thread: RB30 Facts, Figures and Helpful Hints
  1. #141
    84 Post(s)
    Dunno, just a food grade. Haven't really checked it out.
  2. #142
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    How did you go with your carby?
    Did you try to tune it yourself or did you take it back to the guy who rebuilt it?
    At this stage I've tuned it myself, as I just haven't had the opportunity to take time off work to go see the fella who rebuilt it. I know what you mean about how dirty it looks, although I saw it when he put it on and it was really nice and clean looking and ran 100% spot on when he installed it.
    I think it might still be a little rich, still to have a look at the plug and check in more detail, but it feels about right to drive
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  3. #143
    Patrol Guru
    Jul 2014
    6 Post(s)
    Unreal economy mudnut!
    Definitely need a tune on yours Patrol'n, FWIW I got around 23L/100km fully loaded, with a kayak on the roof and towing a 1.5T camper trailer (That was running 35's too, back to 33's now but don't think it's made any difference). Oh and I was thrashing it because I'm an impatient turd lol.
  4. #144
    84 Post(s)
    I also experienced the opposite side of the coin. I hit a big rainstorm past Port Fairy. Fighting a headwind and dodging sheets of water that fill the truck-made grooves in the road. It went up to 19ltrs/100 because I was up and down on the go pedal.
  5. #145
    Legendary dom14's Avatar
    38 Post(s)
    "food grade" means it can safely be eaten....sort of?!
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  6. #146
    38 Post(s)
    Quote Originally Posted by Patrol'n View Post
    It's pretty easy to find out if it's running too rich by simply looking at the spark plug tips for traces of brand new soot.
    Lean is bit tricky, but still can be spotted from spark plug tips by looking for whitish sort of residue, etc.
    Ideally carbies can't be tuned properly on a bench, it's gota be fitted to the vehicle, as each engine's response can be different due to many factors like wear and tear, exhaust system, coolant system, etc etc.
    So, if you take it back to the guy, take the whole vehicle and leave it with him.
    It's even a not easy for an experienced guy to tune a carby by ear, so it will be quite a challenge for us mere mortals.
    i know your carby is running on petrol, but still should look bit better than what I saw in picture after a not too distant past rebuild.
    Perhaps, the kinda trekking you do might have something to do with it.
    Cheetah Outreach
  7. #147
    84 Post(s)
    I occasionally run the "better" hi octane petrol to try and flush out deposits that 91 RON seems to leave in the carby.
  8. #148
    Oct 2014
    WA
    Yep, she has seen more mud, red dirt, water crossings, overgrown tracks etc in the past three years than I think she ever had in her first 21 years... Before I started running a filter on the snorkel I was forever cleaning bits of tree, bugs and bees out of the air cleaner too, that and plenty of fill ups at country fuel stations. the outside of the carb needs a damn good clean, but I washed the engine bay and degreased the other day, and everything still looks grubby... Was so clean and shiny when I bought it! I'll hit the carb with some cleaner to see how it comes up, but when I get time I will definitely take the car and see the bloke who rebuilt it and see what he can find.
    I run 98 whenever I can, as it does go better, but sometimes 91 is all that's available.
    I might have a look at the spark to, since it's definitely still rich, inside the exhaust tip is black so I'll pull the plugs on the weekend and check the dizzy just in case, you never know I guess.
  9. #149
    38 Post(s)
    BTW, 91RON has no colour now. Recently they stopped using the "red dye".
    I think a carby cleaner added to fuel is a better approach to clean the carbies of the gunk from petrol.
    I'm not sure how high octane petrol help clean the carby though.
    Cheetah Outreach
  10. #150
    38 Post(s)
    If the dizzy vacuum advance diaphragm has gone kaput, it will affect the smooth ignition.
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
    Patrol'n (1st May 2017)
