Page 747 of 1056 FirstFirst ... 247647697737745746747748749757797847 ... LastLast
Results 7,461 to 7,470 of 10551
  1. #7461
    175 Post(s)
    I adjusted the idle on it, in the middle of rainy Marysville of all places lol. While waiting for DEPI to clear the road.
    Thanks @nissannewby
  2. The Following User Says Thank You to Hodge For This Useful Post:
    MB (10th April 2017)
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Changed my drive belts, greased all the grease points, did an underbody / loose bolt check, replaced my fan clutch (only 2 years old :-( grrr), rotated my wheels, and had the joy of finding that not only was my fan clutch stuffed, but my steering damper has decided it doesn't want it's oil inside it anymore and let it leak out.... So now that's tomorrow's job after work
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  5. The Following User Says Thank You to Patrol'n For This Useful Post:
  6. #7463
    Jan 2016
    Well... I looked under the bonnet again to see if I could find a good location to mount the newly purchased Redarc BCDC charger, but no luck. So I finally replaced a broken cig lighter with a Narva dual USB socket. I pulled the cig lighter out about 5 years ago, and today thought I'd fix it. I'm pretty chuffed! Now back to looking under the bonnet!
  7. The Following 2 Users Say Thank You to dnl For This Useful Post:
    juzzs8 (10th April 2017), MB (11th April 2017)
  8. #7464
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    What did you do to your Patrol today!
    Took my intercooler off today and flushed it out to remove any oil that may be in there. Now I have convinced myself that it goes harder ha ha
  9. The Following 3 Users Say Thank You to Yeti's Beast For This Useful Post:
    juzzs8 (10th April 2017), MB (11th April 2017), threedogs (12th April 2017)
  10. #7465
    Oct 2014
    WA
    Replaced my steering damper, new shiny one in place, so that's sorted 😀 Went for a test drive, and a bit of belt noise, not a squeal, more of a whine that has a pitch increase with revs. Charge rate dropped a bit, so I got home and checked the new belts, which seemed to have stretched a little. Tightened up the belts, charge rate now seems ok. Didn't whine before I replaced the belts, is there a chance a new belt needs to wear in a little and will quieten down? I hope so, the aircon belt sucked to get on, and it's in front if the alternator belt..... (Wetting down didn't help). Any ideas?
  11. The Following User Says Thank You to Patrol'n For This Useful Post:
    juzzs8 (13th April 2017)
  12. #7466
    Aug 2014
    Perth
    10 Post(s)
    Quote Originally Posted by Patrol'n View Post
    When I had my new alternator fitted I had them fit a new alternator belt, was making a noise but has now stopped completely. Used to happen at start-up but would go away after a while.
  13. The Following 2 Users Say Thank You to gubigfish For This Useful Post:
    juzzs8 (13th April 2017), Patrol'n (11th April 2017)
  14. #7467
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    I installed a Cel-Fi Telstra Mobile Booster so that I have better coverage when I'm out in my truck. It was expensive - but is legally certified so I don't attract the $25K fine for using an illegal signal booster!
    Also relocated my bull-bar 4G Telstra Aerial to the back of the roof rack to avoid interference with the the internal boosted mobile signal.
    Seems to work well ... but not sure I'll know until 50km out of Birdsville.
    I also attached some 100mm PVC pipe to the back of my rooftop tool box so I can stick my tent poles in there.
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  15. The Following 3 Users Say Thank You to Boinzo For This Useful Post:
    GQtdauto (11th April 2017), juzzs8 (11th April 2017), MB (11th April 2017)
  16. #7468
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Got it towed from the mechanics back home
    Mechanic managed 2 move the snapped spark plug a bit but couldn't get it any further, can't justify ( well I can but missus can't ) spending 1500 - 2k in removing the head and getting it machined, I'm not a happy camper and public transport 2 and from work sucks the big one
  17. The Following 4 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    AB (11th April 2017), Clunk (11th April 2017), juzzs8 (11th April 2017), MB (11th April 2017)
  18. #7469
    Dammit Todd! I wish I could help you mate, I would love to see you back in the patrol.
  19. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (11th April 2017), NissanGQ4.2 (11th April 2017)
  20. #7470
    80 Post(s)
    Soak the damn thing with penetrene for a coupla weeks and have another go. Forwards - backwards. Or run it on five cylinders till it warms up and try again. I have had some success drilling out a fastener and peeling the thread out with a pointed pick. I suppose stopping any metal entering the bore is a problem, with that idea. I had to run a tap through the thread on number 4 cylinder when I first got my Old Trol. I used a vaccum cleaner with a small diameter rubber hose to suck out the swarf from the bore.
  21. The Following 2 Users Say Thank You to mudnut For This Useful Post:
