Results 1 to 6 of 6
Thread: EGT gauge kit - Can I benefit from it?!
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    I already have an AFR gauge.
    But, I'm wondering whether it's worth the trouble to have an extra
    EGT gauge kit(fairly cheap) to backup the AFR in case it flops in the future.
    I mean an el cheapo one like below.
    http://www.ebay.com.au/itm/Car-2-52m...8AAOSwIgNXv80k
    It will also make the empty spaces of the three space dash pod look funky!
    Am I wasting time or can it be useful to get an idea about the exhaust gas temperature(as a back up).
    Thanx
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    cant be good, if you really need that backup then invest in a backup you can trust, a EGT Gauge for under $20 cant be good!!
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    dom14 (5th April 2017)
    38 Post(s)
    Yeah, I agree. I will end up getting what I pay for. It will be funky looking but unreliable EGT gauge, later if not sooner.
    Cheetah Outreach
    Hardcore
    central coast nsw
    X2 whats the point in a gauge that monitors engine parameters & you can't trust it!!
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Hay Dom, what the two above said is right on the button. Given that the EGT gauge can vary 50 to 100 deg depending on where the pyro is mounted, adding another inaccuracy to the mix deosn't make a lot of sense. When your driving along and you guage is telling you that the egt is 500 or 600 or maybe 800 or whatever is not much help.
  7. The Following User Says Thank You to 4bye4 For This Useful Post:
    dom14 (7th April 2017)
    38 Post(s)
    Quote Originally Posted by 4bye4 View Post
    Thanx mate. Pyro means the EGT sensor unit, right?
    Yes, I understand it's a waste of time & money.
    Cheetah Outreach
  9. The Following User Says Thank You to dom14 For This Useful Post:
    4bye4 (7th April 2017)
