Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: How much Brake Fluid?
    Legendary dom14's Avatar
    38 Post(s)
    Have you found that the product's plastic and hoses don't react with the brake fluid over time, Matt?
    It shouldn't, should it?!!
    Brake fluid is corrosive when it come to metal, paint, etc but not so much with plastics or rubber, afaik.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. #22
    Patrol Guru
    Jul 2014
    6 Post(s)
    Using a one man bleeder system(for around $7 from Supercheap, Repco, etc), you can still manage it.
    It's that you just need to keep depressing the brake/clutch petal and then keep going outside and check the little bottle and hose to make sure bubble free liquid comes out of the nipple.
    The single tools in the link is worth the money I reckon. For $17, you save lot of trouble. The one man $7 brake bleeder bottle is something you can easily make at home anyway with a little bottle and a piece of hose. Even though I paid some $10 or so for it at supercrap auto, I could've made a better one at home by spending nothing. .
    Aw yeah, I was just going to connect the hose to the bleeder nipple, and the other end straight to the syringe. Use the syringe to suck air/fluid until it's full, close off the line, empty syringe, rinse and repeat.
  3. #23
    Patrol Guru
    Jul 2014
    6 Post(s)
    Also @dom14 do you have a picture of the vac line I'm supposed to plug when adjusting the timing? I went to inbox you but your message box is full. Didn't want to start a new thread.
  4. The Following User Says Thank You to Throbbinhood For This Useful Post:
    dom14 (2nd February 2017)
  5. #24
    84 Post(s)
    The vacuum advance line that is connected to the distributor .
  6. The Following User Says Thank You to mudnut For This Useful Post:
  7. #25
    Patrol Guru
    Jul 2014
    6 Post(s)
    Thanks mudnut, so just plug that black hose in the pic. Cheers.
  8. #26
    38 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    Sure mate. You would need a syringe sightly bigger to make it quicker though.
    The tool on ebay has the larger container, so you don't need to repeat the same action too many times, unless you have a large syringe, which might cost you around ten bucks anyway.
    P.S.
    Sorry mate.
    I just read back and realized you already have the syringe tool with large enough syringe.
    You don't need another new tool.
    Cheetah Outreach
  9. #27
    38 Post(s)
    Sorry mate, just had a some busy times. As mudnut posted, it's the vacuum line attached to the dizzy via the vacuum diaphragm unit.
    You can't miss it.
    Cheetah Outreach
