Results 1 to 8 of 8
Thread: Running lighting wire for 3/4 roof rack
    Nov 2016
    First post.
    Anyone got pictures/ideas that they have run cables for cables up the barn doors preferably without drilling. Rear mounted 3/4 rack with a single rack for the front spottie. Didnt want to run the entire loom up the snorkle for the 3 at the back. Got a bit of an idea how I am gonna do it just seeing it there are better ideas than mine
    Jan 2017
    Did you have any luck with this ijjm87i ?
    Dec 2016
    Yarrabah
    I was reading on a forum ,that you can buy a bolt with a hole in the center so you can run a wire through it .
    It was holding the spare tyre on the right hand door ,but their light was mounted to the spare wheel carrier .
    Hope that helps .
    Craig
    Quote Originally Posted by FNqGu04 View Post
    Hope that helps .
    Craig
    The bolt you mention would me a 10mm x 1.25 pitch eash enough to drill a holl down the middle.
    They drilled 3/16th hole under my rear wheel bracket and fitted a 1/8th rubber grommet.
    Loving the hole in the bolt though.
  5. #5
    Quote Originally Posted by ijjm87i View Post
    First post.
  6. #6
    I tried running a wire in through the rear door but found the
    water would "wick" down the cable and into the cargo area
  7. #7
    Expert Skitzyrex's Avatar
    Jul 2013
    I know you said without drilling but this is what I did. Never had a problem with water getting in.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  8. #8
    Expert johno90's Avatar
    Moranbah QLD
    Gland fittings..... ive got 2 on my roof and have never leaked or rusted if installed properly. You can also use bulkhead detchus fittings but thats $$$$
