Page 712 of 1057 FirstFirst ... 710711712713714 ... LastLast
Results 7,111 to 7,120 of 10566
  1. #7111
    Patrol God Stropp's Avatar
    38 Post(s)
    Im keen to hear your thoughts on the UFI hub Stropp. Whether its engaged the whole time etc etc.
    Much bigger hub, fan blades are more aggressive in curvature and no mine doesn't run all the time. One guy over here says his uses more fuel now but that remains to be seen.
  2. The Following User Says Thank You to Stropp For This Useful Post:
    mudski (11th December 2016)
  3. #7112
    Yeah i saw those fans and they are almost identical to the Infinity fan im running. The hub you have is larger and seems to be real similar to the matching Infinity hub for the fan im using.
    When i overfilled my hub it ran 15c cooler but the noise was unbearable to me as the fan was constantly on. The power loss was minor, i could have dealt with that....
    Interested to hear your thoughts after a few weeks of running it.
    What radiator are you using?
  4. #7113
    Been having a problem while on petrol. No power at all.
    Dropped in two bottles of injector cleaner and 20L of 98. Drove it up past Bacchus Marsh through the hills working it hard up the long hills, 2nd gear 3500 - 4000 revs. Temps weren't too bad considering the weather and the A/C running too, peaked at 97 momentarily.
    Did notice the power switch for the a/t go on by itself when dropping back a gear when in D, haven't really seen it before.
    Seems to drive a lot better power wise now, not quite right but will do another run when I can.
  5. The Following User Says Thank You to jay see For This Useful Post:
    Stropp (12th December 2016)
  6. #7114
    38 Post(s)
    just the stock one currently
  7. The Following User Says Thank You to Stropp For This Useful Post:
    mudski (12th December 2016)
  8. #7115
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    @jay see
    I find that if I Disconnect the Battery for say 1/2 an Hour to reset the ECU it runs a lot better on Petrol.
  9. The Following User Says Thank You to Bob For This Useful Post:
    jay see (12th December 2016)
  10. #7116
    Quote Originally Posted by Bob View Post
    @jay see
    Yeah, I've had the battery disconnected last fortnight, didn't really make a difference. It's almost 20 years old and has probably never had 98 or any type of injector cleaner in it before.
    I think it just needed a high octane overdose to blow off all the crap on the tips.
  11. The Following User Says Thank You to jay see For This Useful Post:
    Bob (12th December 2016)
  12. #7117
    Put some 98 in it and go for a long highway drive. beneboy told me he did this with his car or something similar and it ran better after doing it.
  14. #7118
    I did Mark, read post #7115
  15. #7119
    22 Post(s)
    That was 14.5 hours of straight running though. Then 9 hours the next day. Definatly blew the cobwebs out.
    96 GQ coil/Cab
    08 G6eT
  16. The Following 4 Users Say Thank You to Ben-e-boy For This Useful Post:
    jay see (12th December 2016), mudski (12th December 2016), Stropp (12th December 2016), threedogs (21st December 2016)
  17. #7120
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Replaced sway bar bushes, installed a set of rear draws, checked and topped up all major fluids getting ready for high country trip next week
  18. The Following 5 Users Say Thank You to Bacho86 For This Useful Post:
    Hodge (18th December 2016), Kimbo63 (18th December 2016), mudnut (18th December 2016), threedogs (21st December 2016), Winnie (18th December 2016)
