Page 698 of 1057 FirstFirst ... 696697698699700 ... LastLast
Results 6,971 to 6,980 of 10566
  1. #6971
    I pulled the outer door window seals off a while back to replace the drivers seal as it was broken. The amount of crud in there under the seal was amazing. So i removed all outer door window seals and scrubbed it clean and also washed and scrubbed the seals themselves as the felt section had gone hard over time from the dirt. Just washing them made the felt section much better.
    Was a fairly quick and easy job to do aswell.
    One screw for the front doors and two for the rears.
    That flat section you talk of Kimbo is where i drilled the holes. So that dirt has somewhere to go.
    Kimbo63 (13th September 2016)
  3. #6972
    22 Post(s)
    That's just what they call em.
    They are to suit the weights above.
    When you get them, count the number of active coils (not the top and bottom coil), measure wire diameter, free length and installed length.
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    BigRAWesty (13th September 2016)
  5. #6973
    Western suburbs of Melbourne
    12 Post(s)
    Got the brakes hoses done with a slight adjustment to the rear something brake something so that I get a little more rear braking to make it think I am a little heavier than I am.
    It brakes a hell of a lot better than it did before. Still SHIT but better. Lol
  6. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    mudnut (13th September 2016)
  7. #6974
    I was after actual rates not what they are desribed as. Do as ben-e has said and he will work it out.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #6975
    Got em here but not going in for a bit.
    Patrols have brakes??
    Gong him Red!!
  11. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    BigRAWesty (13th September 2016), MEGOMONSTER (13th September 2016), mudnut (13th September 2016)
  12. #6977
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Its an option you must tick when you order one
  13. The Following 3 Users Say Thank You to Kimbo63 For This Useful Post:
    BigRAWesty (13th September 2016), mudski (14th September 2016), Plasnart (13th September 2016)
  14. #6978
    12 Post(s)
    I think I'll need to go Flintstones style.
  15. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
  16. #6979
    Quote Originally Posted by Kimbo63 View Post
    D'oh!
    I got no toe prints left myself so thinking of joining a gorilla crime gang.
    Gong him Red!!
  17. #6980
    178 Post(s)
    When I bought my Patrol I found the brakes to be very spongy & complained to the car yard I bought it from. They told me to take it to my local Nissan dealership to get fixed at no cost to me. Got it back from the dealer’s workshop who told me they had changed the fluid & bled them (they had the brake fluid was a different colour). Problem was that the brakes felt no different at all.
    I complained & the workshop manager assured me that this was normal for Patrol brakes. Thinking he was treating me as a dumb car owner who knew nothing I made it clear that I did not believe that any properly working brakes could feel so bad. He assurred me again that they were normal & added that Nissan deliberately design them like this to ensure that owners are less likely to lock the brakes accidentally in off road conditions! Convinced he was spinning me a line I continued to complain, whereupon he led me to a customer’s almost new ST wagon & invited me to sit in the driver seat & test the brake pedal for myself. It felt exactly like mine - like if you press hard enough the pedal could touch the floor. In reality the brakes would lock before you got to that point. Nevertheless the brakes inspired no confidence whatsoever. Different pads & rotors on the front gave a noticeable improvement. (Anyone know if there are any performance shoes available for the rear drums?).
