Page 697 of 1057 FirstFirst ... 695696697698699 ... LastLast
Results 6,961 to 6,970 of 10566
  1. #6961
    WA Wheatbelt
    23 Post(s)
    Rossco, please don't!
    Remember, Winnie.....Words not pictures, words not pictures. PML
  2. The Following 3 Users Say Thank You to DX grunt For This Useful Post:
    BigRAWesty (12th September 2016), Plasnart (13th September 2016), Woof (12th September 2016)
  3. #6962
    Feb 2011
    Shed
    45 Post(s)
    Doof doof doof doof doof doof doof you animal ohh yeah doof doof doof
    A little bit more $$ and you couldve had an Andriod double din set up
    for what reason I have no idea why
    Not much chop with an iOS device
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    Kimbo63 (12th September 2016)
  5. #6963
    22 Post(s)
    1450 front and 1350 rear.
    And no idea on shims / valves went in.
    I can ask if your interested.
    Yes that would be good aswell as springs
    96 GQ coil/Cab
    08 G6eT
  6. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  7. #6964
    The specs on shocks are unavailable.
    But have gone medium rate 2" front and standard rear 3" spring.
    What is "medium" and "standard" rate?
  9. #6966
    That's just what they call em.
    They are to suit the weights above.
    were you able to treat any unpainted surfaces or didnt bother about it?
    I didn't have time. I stupidly decided to do this when I was supposed to be going out and forgot about the going out bit. SO it was all put back together in a rush. Once the weather dries out and warms up I will do it when I do the other side.
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (13th September 2016), Kimbo63 (13th September 2016)
  12. #6968
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Grap some photos if you remember mate also it pays to remove the bottom guard bolts and levering out the guards when washing out the mud between the guard and cab nasty trap in there and the drain is a flat square hole gets blocked too easy
  13. The Following User Says Thank You to Kimbo63 For This Useful Post:
    mudski (13th September 2016)
  14. #6969
    Quote Originally Posted by Kimbo63 View Post
    On my other 4x4 it was important to remove the rubber bungs under the doors.
    is it the same for Patrols , or just push a stick up the drain hole to make sure
    they are not blocked ???lol
  15. #6970
    Dec 2015
    Perth WA
    5 Post(s)
    Haven't found a problem with build up in the doors the seals around the Windows seems to do a good job keeping the crap out TD
