Page 691 of 1057 FirstFirst ... 689690691692693 ... LastLast
Results 6,901 to 6,910 of 10566
  1. #6901
    I'm contemplating doing mine. Not looking forward to the task or the cost.
    I just used my trolly jack with length of 100mm square timber on it to lift the body.
    The front seats need to also come out as one of the bolts screws in the opposite way to all others. Dont know why...
    And there is a small crossmember just infront of the rear fuel tank that is bolted to the floor. This needs to be undone too otherwise the rear mounted will be impossible to change over.
    Took me a few hours to do.
    Id recommend replacing the front mount bolts only too. These bolts will be rusted in for sure as they screw into the radiator support panel. All the other bolts will be like new still.
    Cost is not a lot for what you get too.its about $350 from memory for the set or bushes.
    Robo (4th September 2016)
  3. #6902
    Not sure how many body blocks are required but I think I have 6 x 70mm ones here
    Id never need them
    Dark blue poly blocks,,, these are the best to use so Im told
  4. #6903
    Washed it. . . Only took half a day. . .
  5. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    Bacho86 (6th September 2016), King_ady1 (5th September 2016), Stropp (6th September 2016), Woof (5th September 2016)
  6. #6904
    Dec 2013
    Norway
    Went by the garage to se if it has fixt it self. no luck this time either.
    Done building the house now so maby its time to do somthing. It has not been out of the garage in 2 years....
  7. The Following 3 Users Say Thank You to Mikk For This Useful Post:
    Clunk (5th September 2016), threedogs (7th September 2016), Woof (5th September 2016)
  8. #6905
    Ah so you're home then! I bet a little part inside of you is glad to be home but the other much bigger part inside you is busy thinking of ideas for the next one!
  9. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Rossco (5th September 2016), Stropp (6th September 2016)
  10. #6906
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    The crap doesn't come of easy
  11. The Following User Says Thank You to Sir Roofy For This Useful Post:
  12. #6907
    Yep got home on Saturday. To be honest only a very little bit glad to be home it's taking a bit if adjusting! !
    Can't complain tho was a great trip just over 10,000 k all up better change the oil i think. . .
    Yeah maybe a little weekender soon, how did you go with your clutch or don't ask? ! !
  13. The Following User Says Thank You to Rossco For This Useful Post:
    Winnie (5th September 2016)
  14. #6908
    Don't ask! Lol. Nah I have got the new hose to put in but haven't had a chance yet.
    New fuel pump is built and should be here soon too which I am dead keen for! But obviously need to sort the clutch out first
  15. The Following User Says Thank You to Winnie For This Useful Post:
  16. #6909
    Patrol God Stropp's Avatar
    38 Post(s)
    I've been offered a 12mm built new pump for $2000 is that ok no exchange and it's by a reputable company over here but not Ufi
  17. #6910
    WA Wheatbelt
    23 Post(s)
    It took a while, but I washed off all the MUD - from driving on the wet dirt roads around here. lol.
