Results 1 to 10 of 12
Thread: Fuel Consumption Issues
    Aug 2016
    Hi Everone.
    I have recently purchased my first Patrol and unfortunately have been very disappointed with the fuel consumption. I have an 03 GUIII 3.0Ltr on 33's with Bullbar (no winch) and roof rack. Recently burned 1/2 tank (approx) of diesel on a 210km trip??? Surely that can't be right! HELP??
    Jan 2015
    Did you start with a full tank and re fill or are you just working off the guaue.
    If it's the latter it's really guess work.
    Get some accurate figures of true kilometres and actual litres used... it may not be as bad as you think
    Aug 2016
    Quote Originally Posted by Getaboutabit View Post
    Hi mate... Yeah just going off the trip computer and fuel gauge. I know their never 100% accurate but still 210k's and 1/2 tank?? Thats terrible! I used to get better than that in a V8 Falcon
  5. #5
    Im getting abot 370 till the needle points at half tank
    No very acurate .
    Check your tyre pressures at 38-40 psi for HWY work, find some flat ground and go
    Only fill tank to first click
  6. #6
    Aug 2016
    No very acurate .
    Thanks mate... Yeah been reading a bit about the tyre pressures! Definitely going to check them out! Don't know what PSI they are at. Also going to take the rack of the roof (as I don't need it for daily driving) and see if that does much.
  7. #7
    I found a roof rack will use 30-40 Ks per tankfull
  8. #8
    Quote Originally Posted by Malcs15 View Post
    Hi Everone.
    Just for the record is it auto or manual????
  9. #9
    Trip computer?
    and...
    V8 Falcons don't weigh anything like a 'Trol or have the aeros of a brick.
    You need to get the accurate K's (given 33's mean you actually travel further than your Odo states) and accurate litres used.
    You can expect anything between 10 and 16 LPH depending on terrain, wind, auto/manual and driving style.
    Most will average between 12 and 15 LPH on the bitumen anything over that is starting to get excessive
  10. #10
    Aug 2016
    Its a Manual...
