Results 11 to 20 of 25
Thread: slow / lack of power on uphill starts
    May 2016
    Quote Originally Posted by Bloggsy View Post
    Your snow mode switch is not on is it?
    Nope unfortunately
    - With regards to shortcut fix on this beig. If the car is sluggish/no power.
    I turn off the engine, and then back on again and the car takes off fine.
    To me that sounds ECU related - but the transmissions specialist siad their checks had the ECU all ok.
    So could it still be anyone of a number of thins electrical wiring etc and not necessarily the ECU....?
  2. #12
    Just to try a different tack, how about a dirty MAF sensor??
    Disconnect the battery and give it a clean, allow at least 1/2hr
  3. #13
    May 2016
    funny you say that,
    I cleaned it with MAF cleaner about an hr b4 you posted
    Havent got it out for a drive yet
  4. #14
    82 Post(s)
    Since you have not had the vehicle long, remove the earth straps and cables and clean the connections. Add a couple of earths between the chassis and body as well. You never know, it may clear the fault, if you are lucky.
  5. #15
    May 2016
    being not that mechanically minded, would the earth straps / cables be listed in the owners manual, are they hard to locate etc, I've tried google and theres a little bit there that may steer me in the right direction...
  6. #16
    May 2016
    So I have since used MAF cleaner.
    Swapped the relays around.
    And I still get this fault / sluggish at take off.
    Also had the AT light flash 8 times at me - signalling transmission fault still !!
  7. #17
    82 Post(s)
    I hope someone that owns a 4.8 can tell you. There should be a couple that run from the engine block to the body. As for the body to chassis, I have no idea where they would be. Apparently, some auto shops have cables ready to go and they come in different lengths. Just make sure you get a good metal to metal contact when you fit them.
    I also fitted an earth strap from the trailer socket to the chassis.
  8. #18
    May 2016
    So i had a nissan service dealer give it a look over, they couldn't isolate the problem.
    They've said they'd have to fault test through all the wiring until its found and that its an unknown. It could take a number of hrs, it could take days....
    What do i do...
    I'm thinking of looking towards a nissan or 4wd specialist....
    Any recommendations for nissan patrol specialists in Melbournes eastern suburbs....
  9. #19
    Quote Originally Posted by Gav72 View Post
    As MN suggested first measure where you want the earth strap say Auto casing to
    chassis/body or even back to the neg terminal on the battery if its not too long
    What area are you in???
  10. #20
    Patrol God Stropp's Avatar
    36 Post(s)
    What do i do...
    i would take it to a competent auto sparky rather than a nissan dealer if you are chasing electrical gremlins
  11. The Following User Says Thank You to Stropp For This Useful Post:
    Bigcol (23rd November 2017)
