Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Speedo dropping out
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The VSS sends the signal to the instrument computer mounted in the instrument cluster. From here the signal is sent to the engine computer, auto computer and cruise control computer.
    It's strange that the cruise control stops working but the auto shift isn't affected. It might be a problem with the instrument computer. Were you able to check the vehicle speed via a scan tool?
  2. The Following User Says Thank You to Yendor For This Useful Post:
    Chubba (7th June 2016)
  3. #12
    84 Post(s)
    [QUOTE=Kimbo63;680980]
    While using your fingers to twist/flick the drive you should see about 2-3 volts momentarily on AC volts on your meter.
    To make it a lot easier to attach the alligator clips, I used a knife to strip a little section of both wires to connect the multimeter and will use a bit of silicon to seal them properly.
    Hey mudnut that is not good practice cutting insulation of your wires it can and will cause green death get yourself some multimeter probe spoons cheap as chips saves a lot of hassles down the track Attachment 67374
    These just slip in the back of the plug
    :-) zzzzzzzzzzzzz
    Yep, have some, but most blokes don't have them. The silicon will stop any ingress of moisture if pressed into the gap.
    Kimbo63 (7th June 2016)
  5. #13
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    No mate. Don't have one.
    Would you say that the problem probably is in the instrument cluster?
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  6. #14
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Chubba View Post
    Yeah that would be my guess. Probably not the gauge but the instrument ECU.
    It sounds like the VSS is working.
  7. The Following User Says Thank You to Yendor For This Useful Post:
