Results 1 to 10 of 12
Thread: 4.2 duel fuel petrol not idling
    May 2015
    Hi all, ive tried to find a similar thread, can anyone direct me or have you seen this problem.
    I have a problen on a carby 4.2, dual fuel. The car ran fine on both fuels and regularly was swapped between each. A collapsed muffler was causing it to struggle which i eventually replaced after multiple patch ups. Had trouble with idle on petrol after that however plenty of power. On gas it ran fine. Also lagged on take off petrol only.
    I rebuilt the carby so the power piston stopped lagging.
    Ran perfect on fuel, swapped to gas also perfect. Swapped back to petrol and it wont idle. Still power under load but now backfiring out the exhaust when decellerating and dies under 1000rpm.
    Tested the gas valve by shutting off the tank so its not duel fuelling. Fuel pump is fine and new filter. No air leaks.
    Had another issue at the same time which was the gas solenoid had cracked and was shorting and blowing a fuse (i think) which is why i checked fir duel fuelling from a leaky solenoid.
    What i font understand is why it ran oerfectly for days then after running gas and back to petrol it faults.
    Any idea?
    84 Post(s)
    Check the changeover switch for dud contacts or loose wires.
    May 2016
    So, issues only came after fixing/replacing the exhaust?
    If so, you need both petrol and gas carbs re-tuned to suit the changed airflow of the motor.
    There is no legal cure for STUPID!
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by LostBenji View Post
    Both carbs?
    If it's running fine on gas then it would seem that the gas system is ok.
    I don't think any TB42 has ever had fine enough tolerances to require tuning a carby to an exhaust.
    >>>tappin from tassie
    Hello from Under Down Under!
  5. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    dom14 (30th May 2016), threedogs (27th May 2016)
    Aug 2011
    North West Tas
    56 Post(s)
    As mudnut said maybe check the changeover switch?
    The Tb42 carby can be a very temperamental thing. If it ran well on petrol after the carby rebuild then it would seem that all was rebuilt correctly.
    Most likely sounds like a fuel starvation problem.
    How have you checked that the fuel pump is good?
    I have heard that backfiring can damage the float too.
    What are the points like?
    The timing for gas is set quite a bit further advanced than what petrol likes and if there's a slight issue with spark then it will be more pronounced when on petrol.
    >>>tappin from tassie
  7. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    dom14 (30th May 2016), mudnut (27th May 2016)
    84 Post(s)
    As Lucas posted, backfiring can cause damage. Check all of the vacuum diaphragms for splits or holes. ( Choke break, vac advance and fast idle actuator).
    Have a look at this thread. I know it is RB30, but there is a section that covers dual fuel carbies.
    http://www.nissanpatrol.com.au/forum...-Helpful-Hints
  9. The Following User Says Thank You to mudnut For This Useful Post:
  10. #7
    Do these carbies dry out or have a power valve like a Holley.
    Backfiring on gas can been too lean a mixture or air leaks
    as well
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #8
    Aug 2011
    North West Tas
    56 Post(s)
    as well
    They do dry out if only run on gas for a very long period but as the op said it was running fine on petrol previously AND it's been rebuilt then I think it's safe to assume it shouldn't be dried out. The op also said it's running fine on gas.
    >>>tappin from tassie
  13. #9
    You will usually find 90% of dual fuel problems are electric.
    Are your leads in good condition if dirty they may be shorting?
    Its not starving for fuel is it, has it got an inline cage filter??
  14. #10
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    first thing you have to do is............
    check and replace ALL plugs & wiring for the Gas system that looks dodgy, those crimped plugs have been on there for close to 20years +
    when you replaced the fuel solenoid, did you also check that all were tight and the Earths were all attached and having good contact......?
    has it got electronic ignition or the old points??
    if electronic ignition, check the Earths for that
    if not
    check your Tachometric relay - it may be cactii or on its way
    N# 1 priority is to check and replace any of the old wiring that looks old / tatty / corroded / crappy
    clean and replace (as necessary) Rotor Cap & Plug Leads (get Original Cap - works better than Aftermarket) get good quality Leads - designed for Gas Cars
    have you got a "modified" rotor button - tis about 2-3mm longer than standard - gives a better spark AT the right place
    as has been stated earlier, your timing for Gas should be around thew 15-20*BTDC while Petrol will be around 5-8* BTDC
    if you tune it correctly for Gas only, you will get great economy & power (for Gas) and it will get hot running petrol (as your timing is out) not baddly, but it will be hotter than normal, and your fuel economy will be shyte
  15. The Following User Says Thank You to Bigcol For This Useful Post:
