Page 23 of 44 FirstFirst ... 2122232425 ... LastLast
Results 221 to 230 of 434
Thread: Threedogs motor thread
  1. #221
    476 Post(s)
    Me too......
    Mark, when you span the viscous hub it had no belt or plastic fan on correct. Spinning it like that it's on the bearing. With everything back on and stone cold it moved one blade.
    A/c fan is only meant to go on with air con regardless of temp or when temp is high 90 or 100 degree.
    Correct John. I spun the hub with no fan on it. I did it to check if it was lose. There is a procedure to check if the hub is engaging or not but I can't remember tbh how it goes. I'd have to look it up.
  2. #222
    I only know of the spin test, but it must be cold if spinning when hot you can see that is spins alot more freely.
  3. #223
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    The following taken off another site
    Re: How do I test a viscous fan hub?
    Without taking it off the vehicle, the fan hub should be locked up for about 30 secs to a minute on start-up from cold, then it should let the fan free-wheel until the temp rises above normal; so if you start it from cold and watch/listen for that 30-60 secs of engaged fan before it slackens off, then leave it sit there on a fast idle for a while with the heater on high (A/C off), maybe even put a piece of cardboard in front of the grille/radiator to limit air flow & encourage it to reach operating temp & then go over, the fan should cut in again and you should be able to see/feel/hear it when it cuts in again. Let it do it's cool down thing & then shut the engine down, the fan should stop pretty much straight away if the temp is at or above normal, if it spins on for more than one rotation on shutdown or you haven't been able to see/feel/hear the airflow increase as above, the viscous fan hub isn't doing it's thing properly.
  4. The Following 4 Users Say Thank You to Bob For This Useful Post:
    jay see (19th April 2016), morton2478 (21st April 2016), mudnut (19th April 2016), mudski (19th April 2016)
  5. #224
    I don't know how many times Yendor or I have to post this but anyway...
    Under normal loads and conditions the A/C fan has bugger all to do for overheating.
    You can take it off and hoik it down a long drop if you want.
    Later model 'trols don't even have them.
    Where fitted the A/C fan should run under two conditions;
    Either the A/C is selected
    OR
    The coolant is above 100 degrees C
    When the A/C fan starts running with the A/C OFF it means the engine is already starting to overheat because the coolant sensor has detected that it is at 100 degrees AFTER it has passed thru the radiator.
    Ergo, unless it is a stinker of a day or you are loaded up then something is wrong
  6. The Following 5 Users Say Thank You to the evil twin For This Useful Post:
    Bloodyaussie (19th April 2016), jay see (19th April 2016), rusty_nail (19th April 2016), taslucas (19th April 2016), threedogs (20th April 2016)
  7. #225
    OR
    Probably a few times more
  8. The Following 2 Users Say Thank You to Clunk For This Useful Post:
  9. #226
    476 Post(s)
    OR
    My coolant temp has been over 100c many times and the fan never comes on. Now whether my particular model is designed not to do this or not. I dont know. I might go for a drive tomorrow up the hills behind me and give it a flogging and get the water temp over 100c, which wont be hard, stop and double check on this.
  10. #227
    Before you go put on the air con as if it's a 40 degree day and have a look at the fan, can't remember if you said that it works only with the air con on or never.
  11. #228
    I'm sure it has... certainly mine did many times in the WA summers
    The 'coolant temp' temp isn't measured in the same place or by the same sensor as the Coolant Temp 100 degree switch (if fitted)
  12. #229
    I think I just "burped" a bubble out of it ,{air pocket}
  13. #230
    So what's new?
