Page 622 of 1057 FirstFirst ... 620621622623624 ... LastLast
Results 6,211 to 6,220 of 10566
  1. #6211
    wired in this single USB port The seller says 5 amps
    but more inclined to think 2 amp.
    Its jus velcro in sitchu ATM, its puprose is to keep any usb leads
    out of the road and not hanging every which way. Ill probably end up
    buying the correct size USb cable required
  2. #6212
    Got the wheel alignment done at Pro Axle. They checked the entire front end while they were at it, bushes camber etc. Everything is spot on. Now to find where this front end knock is coming from and I'm complete. Lol They suggest to look at the steering shaft flex joint. While it looks o.k, at around 300K old, it maybe due for a change.
    BigRAWesty (23rd March 2016)
  4. #6213
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Cab mounts ? Maybe
  5. #6214
    Holes not flogged out on the diff to radius arm points??
    My gq flex joint is original at 525***..
    If thats 300ks old everything else is 300ks old as well
  7. #6216
    Nah, nearly every single item on Mudski's car has been changed for new within the last few years!
    Can't be much original gear left on it!
  8. The Following User Says Thank You to Winnie For This Useful Post:
    mudski (23rd March 2016)
  9. #6217
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Got it ready to go away at Easter - pumped tyres, checked the fluids, cleaned the MAF and all that stuff. Also checked the trailer . All good.
  10. #6218
    Quote Originally Posted by Kimbo63 View Post
    Cab mounts ? Maybe
    Changed them not long ago...
    Holes only slightly flogged. I just went and got new bolts, plus longer bolts too with washers so i can weld on washers if i get my rrs into gear.
    Not quite everything. But i trying my hardest...
    I found the sway bar bolts are flogged out. They are only 6 months old too.
    So i got new bolts for this, plus 14mm bolts too so i can drill out the sway bar end to fit the larger bolt, and not use those metal sleeves in the rose joint.
    I pull the bolts up tight and noise is still there.
    Wondering if the mushroom bushes on the radius arms are flogged. They're not old too though.
    Some Superior arms would do away with the sh!t idea of the mushroom bushes.
    Gotta work out how to remove the steering coupling to see what condition its in...
  11. #6219
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Nut behind the wheel loose?
  12. #6220
    Jul 2015
    Fitted or should imsay had fitted a Steinburge today
    Gave an increase in power /touque 20%
    Makes the vehicle more driveable
  13. The Following User Says Thank You to Fwdpatrol For This Useful Post:
    threedogs (24th March 2016)
