Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 2 in 1 gauges
    2 in 1 gauges
    Ok so starting to pit together a list of things I'd like to see in this gu..
    One of the things are the gauges..
    what I'm after is how are people finding the 2 in 1 gauges?
    From pics of say the egt and boost gauge the increments are very fine and the difference from say 450 degrees to 550 or 10 psi to 15 psi is a couple of needle thicknesses..
    Are they difficult to glance at to see what's going on and if you bought the 2 in 1 gauges do you wish you'd bought seperate or are you happy? ?
    Have a look at McNally gauges. I use their boost and egt gauge in a single cup in between the speedo and tacho. Easy to read too.
    Avo (13th January 2016)
    178 Post(s)
    I chose to go with 2 in 1 gauges & am very pleased with them. Clarity & ease of reading was high on my priority list, as was trying not to clutter up the limited real estate in the GU cab any more than necessary. The EGT/boost gauge shows the boost in digital figures at the bottom & the EGT on the ‘analogue’ gauge which is large enough to easily read at a glance. The water temp & oil pressure gauge has an ‘analogue’ scale on either side of the gauge for each & is also easy to read. It also has an option for another temp reading if wanted, presented as a digital readout at the bottom of the gauge, but I didn’t bother with that, thinking it might make things a bit too ‘busy’. Colour & contrast can be adjusted to suit. Not cheap but I haven’t seen better. Better in reality than in the photo as there is more contrast between the ‘needle’ & the face than the photo shows.
  5. The Following 5 Users Say Thank You to Cuppa For This Useful Post:
    Avo (13th January 2016), Bigcol (15th January 2016), BigRAWesty (13th January 2016), blocko05 (14th January 2016), Rock Trol (16th January 2016)
    That's option is a good setup..
    might just have to save a bit more to outlay on the redarc gauges..
    They do seem to be one of the best out there..
    Hey Cuppa, can you move the recline in the gauges?
    178 Post(s)
    Do you mean the red line Winnie? If so, no you can’t, but you can set the alarms wherever you want. They are both audible & visual (beeps & background changes to a pre-set colour).
    I have my EGT set at 525deg, oil pressure at a tad under 20psi & coolant at 100deg.
  9. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    Bigcol (15th January 2016), BigRAWesty (14th January 2016)
  10. #7
    Yeah, bloody typing on the phone.
    That's cool though.
  11. #8
    I think there is too much going on in 2 in 1 gauges for see whats happening at a quick glance as you point out.
    VDO do a great gauge ,very easy to read as well. I have speco white face and find them easy as well.
    PM me if you want to do the dual pillar pod, cancell that Ill sms details for you.
    Plenty of pods that sit on top the dash too.
    Redarc are just Autron copies
  12. #9
    I like this style and those contact details will be for this shop
    http://www.ebay.com.au/itm/4-GAUGE-D...8AAOSw3ydV5XOk
  13. #10
    No they aren't, they ARE Autron gauges. Redarc bought Autron, or at least their gauges division.
  14. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    Bacho86 (15th January 2016), Bigcol (15th January 2016), BigRAWesty (14th January 2016)
