Results 1 to 10 of 13
Thread: Growlers socks
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Growlers socks
    Hi guys, as you are all aware we have been melting here in SA, so the old A/C has been getting a bit of a work out.
    Problem is now the rig smells like Growlers socks, When you hop in from previous use and as soon as I turn the A/C on it smells like poop, mouldy musty disgusting stench for the first few minutes. Anyone else had this problem and what can be done to stop it.
    Seriously it's not a healthy smell
    84 Post(s)
    My Q had the same problem, so I pulled the fan housing out. I used a vacuum cleaner to suck as much crud out of the cooler fins and to unblock the drain. I then used a disinfectant and water to wash it out. I also used an air hose (with low pressure) to dry it out.
    I have now fitted an air filter to stop the leaves, rat droppings and dust from entering the fan.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    wildgu6 (20th December 2015)
    Leah's Navara had the exact same smell but Growler lives miles away from me so I looked further into it and the drain tray was just full of crud from all the dust.
  5. The Following User Says Thank You to AB For This Useful Post:
    Feb 2011
    Shed
    45 Post(s)
    Mine did it for a while when I first got it but it's cleared itself up
    Sep 2010
    Adelaide S.A
    mine seems to be getting worse the more I use it
    Sep 2011
    adelaide
    18 Post(s)
    g`day Pete .
    Check the drain holes on either side of the air in take, these some times block with mud and crud.
    Beers and Cheers mate
  9. The Following User Says Thank You to pearcey For This Useful Post:
  10. #7
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Or you just got use to your own sent.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  11. The Following 3 Users Say Thank You to Chubba For This Useful Post:
    Avo (21st December 2015), growler2058 (21st December 2015), wildgu6 (20th December 2015)
  12. #8
    Sep 2010
    Adelaide S.A
    Cheers guys, got a few days off over chrissy, so might have a sniff around and see what I can come up with,
    Not familiar with A/Cs, where do I start looking for the drain holes on an 08 3lt crd
  13. #9
    Sep 2011
    adelaide
    18 Post(s)
    The air inlet to the system from the outside the drain hole are normally inside the front guards.
    They get blocked with leaves and dirt that finds it way through the vents up at the windscreen.
    Cause more rust than stink, but sometimes rotting plant life does stink.
    Sorry not much help mate, ask at a panel shop they may be able to point you in the right direction.
  14. The Following User Says Thank You to pearcey For This Useful Post:
    wildgu6 (21st December 2015)
  15. #10
    Aug 2010
    adelaide
    there is a disinfectant and deoderant spray you can get from super cheep or ropco or aircon mob
    have aircon on and spray into air intake works well but cant remember whats it called
    OH LEATHER IS NICE
  16. The Following User Says Thank You to my third 256 For This Useful Post:
