Page 567 of 1057 FirstFirst ... 565566567568569 ... LastLast
Results 5,661 to 5,670 of 10566
  1. #5661
    177 Post(s)
    Put a set of new shoes on. Mickey Thompson P3's in 285/75/16 on a set of black rims.
  2. The Following 6 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (11th November 2015), mudski (13th November 2015), Onkey (15th November 2015), Rocket55 (11th November 2015), Stropp (12th November 2015), threedogs (12th November 2015)
  3. #5662
    Whyalla SA
    Took off the 2 steel plates under the winch. They were showing signs of a bit of rust and the Nissan paint was lifting.
    Cut the paint and rust back to shiny steel, painted then with Septone rust converter them sprayed the with rust shield.
    Bolted the z looking plate to the main one and sprayed the bolts with the rsut shield.
    Now all back in place.
    Next some of the front wheel arches. Getting the plastic panel bits of looks like a nuisance.
    Also loaded new steel cable back onto the 9500lb winch. Had to replace the old cable before the new winch goes on.
    Put on a 44.7kN, (4.6t), min breaking force cable from Nobel's rope.
  4. #5663
    Nov 2010
    Getting a life...
    38 Post(s)
    Received and fitted. Thx John.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. The Following 4 Users Say Thank You to katwoman For This Useful Post:
    4bye4 (12th November 2015), Hodge (12th November 2015), Stropp (12th November 2015), threedogs (12th November 2015)
  6. #5664
    Ah good to see they arrived a painless fit too I see
    katwoman (12th November 2015)
  8. #5665
    Nov 2010
    Getting a life...
    38 Post(s)
    Not exactly painless. A little filing but still went on pretty good.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  9. The Following 2 Users Say Thank You to katwoman For This Useful Post:
  10. #5666
    Patrol God Stropp's Avatar
    38 Post(s)
    same as mine
  11. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    katwoman (12th November 2015), threedogs (15th November 2015)
  12. #5667
    38 Post(s)
    Not today but mounted to compressor in the engine bay, but tight for space.
  13. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    Hodge (15th November 2015), threedogs (15th November 2015)
  14. #5668
    Patrol Guru Rocket55's Avatar
    Sydney
    Installed a TowPro trailer brake and a Breaksafe 6000 monitor, along with wiring up the 12 pin plug and Anderson plug down the back.
    Cheers Rod
    My Build 2005 TD42TI
  15. The Following User Says Thank You to Rocket55 For This Useful Post:
    BigRAWesty (15th November 2015)
  16. #5669
    gave the patrol a good wash now Im going to Clay bar it and then polish , yeah right lol
    EDIT you can shove the clay bar thing how labour intensive is that
    brought some Armourall polish and must admit it has come up awesome.
    I'll do the rest tomorrow some time
  17. #5670
    Expert Skitzyrex's Avatar
    Jul 2013
    Haha, I've spent a full 8 hours washing clay bar polishing before. Not the best fun.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
