Results 21 to 30 of 40
Thread: Steering shake continuation
    Advanced peterbr1's Avatar
    Apr 2015
    Melbourne western subs
    Good point... what size shim is best to use?
    Don't know what thickness shims that might be one for the Nissan stealership people
  2. #22
    Thin ones
    ROFL, typical Clunk....
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    Clunk (8th November 2015)
  4. #23
    Quote Originally Posted by peterbr1 View Post
    Cool... what info do I need to tell them so they get the right ones in for me?
  5. #24
    That you have the wobbles
  6. #25
    Tried that... they said because it was lifted it was a castor issue
  7. #26
    Apr 2015
    I measured the shims I took out of my car, 0.5mm if that helps
  8. #27
    So, you replaced them with new ones the same size and wobbles cured?
  9. #28
    Apr 2015
    No around 6 months ago my car developed the wobbles I removed the shims and all is good, I measured those shims I took out 6 months ago and gave you the thickness of them...
  10. #29
    Hardcore
    central coast nsw
    from memory .5mm is the thickest one they make.
    got me thinking why not make your own shims.
    pattern looks easy.
    search shim metal sheet.
    ebay item no 120898743299
    Material - Steel
    6 sheets 150mm x150mm
    2 x 0.05mm (0.002") thick
    2 x 0.075mm (0.003") thick
    1 x 0.15mm (0.006") thick
    1 x 0.25mm (0.010") thick
    approx $30 inc del
    Could be of use I recon
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  11. #30
    .762mm is the thickest shim. Then .254, .127, .075 and .050mm.
    the evil twin (8th November 2015)
