Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: tyre inflators
    Nov 2014
    tyre inflators
    Hi All
    This might be a stupid question but, tyre deflators will let the air out automatically to a preset pressure, is there an opposite device? A tyre inflator that cuts out at a preset pressure when inflating? Basicly you don't need to keep checking with a tyre gage, just attach the device to the air hose then to the tyre valve, walk away and let it do its job.
    1994 GQ 4.2L Y60 turbo Diesel Patrol ute (was a wagon), 4 inch lift, 2 inch body lift, 33 inch Maxxis Bighorn Tyres, endless air compressor, front and rear lockers, 25L water tank, endless hot water, winch, rock lights, reverse camera, dual battery.
    Its called a servo. lol
    I haven't heard of any such product not to say there isnt one out there
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Unfortunally only at servos. Some have air stations you can dial a pressure and it will stop when that is reached. A portable device wouod be a bonus if you are on/off road all the time.
    Great idea for a new product for someone eh,,
  5. #5
    Just get one of those ARB inflators, or similar, with the gauge on the unit itself. Just takes a lift of the thumb off the trigger and it shows the pressure...
  6. The Following 4 Users Say Thank You to mudski For This Useful Post:
    4bye4 (26th October 2015), BigRAWesty (26th October 2015), Hodge (26th October 2015), wildgu6 (29th October 2015)
    Patrol Guru
    Jul 2014
    6 Post(s)
    But then you have to stay there holding it..
    Quote Originally Posted by Throbbinhood View Post
    I'm sure you could rig something up to hold it down.
  9. The Following User Says Thank You to Winnie For This Useful Post:
    Avo (26th October 2015)
  10. #8
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Some tyre shops did have what was called a "Green ring valve stem".
    An Aussie invention, looked like a normal tubeless valve that was fitted to the rim the same as a regular tubeless valve.
    After inflating the tyre to the correct pressure you could turn the stem so the green ring could be seen.
    If the pressure dropped, the green ring could not be seen. The green ring would appear again when you inflated again.
    Not sure if they are still available.
    Best to ask a tyre shop
    You can get those one that replace the valve cap but chances are they would get knocked off.
    Was a CRD
  11. #9
    What you want to do whilst the tyre is inflating for a few minutes?
    My Aldi compressor, which is the same as those Mean Mother ones, just has the clip on chuck and it keeps pumping away until I look at the gauge. One could be made to fit inline from the chuck to the valve using a pressure relief valve so it just releases the air from the compressor but you'd need to put a one way valve in aswell so the air doesn't come back out once the pressure is reached. Could be made pretty easily. Is it worth your while though?
    Hmm, I think I have most of the parts here to make something. I might have to look into this now...
    Lol
  12. #10
    Patrol Guru
    Jul 2014
    6 Post(s)
    I do heaps in the time that my tyres are inflating.. Clean the lights/mirrors/windows, put the snatchy away if it's not dirty, wind in winch rope, put any rubbish or whatever in a bag, socialize with others, etc.
    Plus, means I'm not huddling over for a valve that's at the bottom leading to a sore back.
    Mine has a clip on chuck, and I've got a digital pressure gauge that I use and just clip em on off every now and then. I know roughly when I'm close to pressure.
    That said, would be great to be able to set 38psi and walk away, and when I hear the relief open up, time for the next wheel.
  13. The Following User Says Thank You to Throbbinhood For This Useful Post:
    Winnie (26th October 2015)
