Page 18 of 46 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 456
Thread: Rockets Wagon
  1. #171
    What are you buying now?!
  2. #172
    Patrol Guru Rocket55's Avatar
    Sydney
    I haven't opened that box yet, but it should be a black 4" snorkle with ram head. Just waiting for the 4" airbox, CC Cooler, injectors, 12mm pump, 18g turbo, clutch and aluminium flywheel to turn up...
    I will be conflicted soon between watching bathurst or installing this stuff.
    Cheers Rod
    My Build 2005 TD42TI
  3. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (24th September 2015)
  4. #173
    Thomastown, Melbourne
    6 Post(s)
    Do both.....
  5. #174
    Quote Originally Posted by Rocket55 View Post
    Bring the telly into the shed! Haha
    What airbox are you going to be using? And who are you using for the 12mm pump?
  6. #175
    Sydney
    It's a Fatz 4" airbox and a UFI pump.
    Cheers Rod
  7. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    Hodge (24th September 2015), Winnie (24th September 2015)
  8. #176
    176 Post(s)
    Geez mate will there be anything left of the standard 4.2 on that car? lol
    Sydney
    Hahaha I just hope the performance doesn't remain standard..
    Steering wheel is standard
    Cheers Rod
  10. #178
    176 Post(s)
    Highly doubt it considering all the goodies you're throwing at it ...
    Will you be doing some sort of a dyno tune on this, before and after to see results? Would be keen to see the difference.
    Should be real happy with the gains in perormance with that setup.
    Order your cc cooler now though if you havent already. They really do lack in delivery time and customer service.
  12. #180
    Sydney
    It won't be getting a dyno run before hand, I don't have time. It might get a dyno run when it's finished if I can find some time to get it done. ATM I'm being told I've got to take it to Melb or Bris to get it tuned as there's no one in Syd that they recommend. Also having trouble getting the flywheel, so the clutch won't be going in until that turns up, not pulling the gearbox out twice. As a result it might not run up fully on the dyno anyway without slipping. Needs to be operational by mid Nov for a trip.
    Cheers Rod
