Page 18 of 101 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 1003
Thread: Hodge's new 4.2
  1. #171
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Thanks Rod, I did find that image online. They use the standard red & yellow wires in their diagram but the original thermocouple is too short and the VDO extension uses brown & red.
    I was hoping to see how the ends of the extension cable are terminated.
    I think I'll just use standard lugs and test it on the bench first.
    John
  2. #172
    I think I still have all the literature from my gauges that might have that info john.
  3. #173
    Morayfield, QLD
    Did you use the long red twin core extension that VDO supply?
    What I'd like to know is if I can just crimp on a couple of standard flat connectors or if they have to be a particular metal.
    I also have no idea how much, if anything, was cut from the original cable.
    Info I've been able to find suggests the VDO gauges can't simply use any K type thermocouple like most EGT gauges can.
    John
  4. #174
    177 Post(s)
    Going to attempt my first oil and filter change this weekend. Never done it do there !might be a stuffed td42 after this weekend for sale. Wish me luck ???
    15w-40 ???
    Sent from my SM-T705Y using Tapatalk
    Yep, I use Caltex Delo400
  6. The Following User Says Thank You to Winnie For This Useful Post:
    Hodge (18th September 2015)
  7. #176
    177 Post(s)
    Where do you score some ??
    I work around the corner from the Caltex depot here in Warragul, I buy it in 20L drums for under $100
  9. The Following User Says Thank You to Winnie For This Useful Post:
  10. #178
    Castrol RX Super is good for these motors too.
  12. #179
    177 Post(s)
    Very hard to find Delo. Nearest place is caltex depot dandenong.
    Not as good as others in my experince.
    Basically any ci-4 or ci-4+ spec oil will be fine.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
